Hot Voltage Regulator? |
MikeM |
Oct 27 2016, 05:51 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I checked my charging voltage at the battery and it was high. It was almost 16.
So I went to install my spare and the regulator was very hot!! I've never noticed before because I never checked!! Should it be hot? I installed my spare and it allowed a charge rate of 13.4 but it also began to get hot. Hope my alternator isn't bad!! Cheers Mike |
MikeM |
Oct 30 2016, 09:15 AM
Thanks Brad...is the alternator grounded at the relay board?
Or are you saying I should add a ground somewhere? Mike |
pbanders |
Oct 30 2016, 01:45 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Thanks Brad...is the alternator grounded at the relay board? Or are you saying I should add a ground somewhere? Mike Answered in PM. Alternator should have a ground strap, if there isn't one present, use 8 gauge wire and make one yourself, bolt to alternator and to chassis. Do NOT ground the voltage regulator at the relay board, because if there is a poor alternator ground, you'll get a significant current through the D- wire in the alternator harness and possibly melt it or start a fire. Do NOT mount the voltage regulator on to a chassis surface!!! |
Lo-Fi Version | Time is now: 20th May 2024 - 01:12 PM |
