Weber 44 IDF Question |
orbit398 |
Nov 1 2016, 09:57 AM
Member Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
Just looking to see if someone can help pin point an issue I am having – assume it’s a carb issue.
Here is what I have: 2.0 liter with flat top pistons (euro style), has ~160 psi on all cylinders, carb cam, bursch exhaust, dual Weber 44 IDF carb set up, idle jet = 55, main jet = 145, F11 emulsion tube, 200 air correction. Carbs are synced and pull the same at idle as well as about 1500. I live in Houston (sea level). I have read and followed several write-ups on tuning the Weber carbs. Overall, the car runs great above about 2200 rpm. It idles excellent. Issue: Still getting the occasional popping. More importantly, while under easy acceleration (throttle slightly opened/just limping along in traffic) ~around 2000/2200 rpm, the engine seems to be missing or it shutters. If I open the throttle just a bit more, it disappears and runs great. I cannot replicate this by just revving the motor up in neutral; does this only under a load?? What could be the issue here? I plan to recheck synchronization/insure carbs pulling equally, spray carb cleaner/starter fluid to check for air leaks, try to ensure butterflies are opening equally. Just puzzled at what it could be. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:11 AM |
