| 3d914 |
Nov 6 2016, 12:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Working on the support frame for my trunk lid so it opens from the back instead of the front. I'm planning on using 14ga steel, but may need to go to 16ga if I can't find a tool for this. Preferably I'd like an angled, not flat, flange. Most the hand or pneumatic tools out there only do a flat flange for like an overlap weld joint. Anyone seen or used a hand (pneumatic) tool with something other than a flat flange?
Here's the drawing for the support frame (in orange). They'll plasma cut the pieces for me, so I need to find a method to flange these cutouts that lighten the piece, to add the strength back in. ![]() If I can't find a hand tool for this, I'll need to go with a press and some hole flange tools - but those I can add without having these shapes pre-cut. ![]() |
| 914_teener |
Nov 7 2016, 04:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Rick....nice work.
Never forget you and Mark working on Jaimes quarter panel in the parking lot at the WCR. |
3d914 Sheet metal help - Need angled flange tool? Nov 6 2016, 12:26 PM
McMark A bead roller might be able to do what you need, b... Nov 6 2016, 01:54 PM
3d914
A bead roller might be able to do what you need, ... Nov 6 2016, 05:59 PM
McMark
With all the pneumatic flange tools out there, yo... Nov 7 2016, 11:39 AM
914forme
With all the pneumatic flange tools out there, y... Nov 7 2016, 01:28 PM
dlee6204 So what are the internal cutouts for? Weight savi... Nov 6 2016, 06:12 PM
3d914
So what are the internal cutouts for? Weight sav... Nov 14 2016, 07:03 PM
914forme Hammer forming them is the best way to do them as ... Nov 6 2016, 07:00 PM
914_teener
Hammer forming them is the best way to do them as... Nov 7 2016, 11:01 AM
mbseto :agree:
Hammer form using McMark's wooden bu... Nov 7 2016, 10:45 AM
Valy Not sure how much reinforcing you need but this ma... Nov 7 2016, 11:13 AM
rick 918-S I think I used Plywood as a buck for this panel. I... Nov 7 2016, 03:51 PM
3d914
I think I used Plywood as a buck for this panel. ... Nov 14 2016, 07:07 PM
rick 918-S
I think I used Plywood as a buck for this panel.... Nov 15 2016, 07:26 AM
tygaboy If you're not stuck on those cut out shapes, y... Nov 14 2016, 07:13 PM
3d914
If you're not stuck on those cut out shapes, ... Nov 16 2016, 07:51 AM
mbseto This is a mini-clinic. Nov 15 2016, 10:25 AM
3d914 Rick, your example makes sense, and thanks for sha... Nov 16 2016, 08:06 AM
3d914 Here's what I came up with. Found a 1.5" ... Dec 4 2016, 10:10 AM
Catorse Looks great and will be plenty strong. Where did y... Dec 4 2016, 12:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th June 2026 - 05:57 PM |
