> Upgraded Coil, now Alternator Light on
Tastyplacement
post Nov 10 2016, 07:59 AM
914world, please save me again from my mediocrity.
2316cc T4. I used to have an Empi distributor with Bosch blue coil. I upgraded to pertronix 45kv 0.3 ohm coil and pertronix distributor. Great spark now, easier starts, but my alt. light stays on. Previously, i would have to get rpm over 2500 to make light go off, now no spike in rpm will make the light go off.
I have led bulbs in dash, and i am willing to do the 100 ohm resistor mod to the alt light if that is necessary.
pbanders
post Nov 10 2016, 12:28 PM
Suggest you read this and follow the appropriate tests. Alternator light is an active part of the system, not just an indicator.
http://www.ratwell.com/technical/ChargingSystem.html
The bulb is a 1.2W bulb, so a 120 ohm / 2 W resistor across an LED light would provide the same zero ampere speed (~500 engine rpm) as the stock incandescent and similar operation. Note you can't use a crappy 1/4 W or 1/2 W carbon film resistor, you'd have to use a 2 W power resistor. IMO, you'd be better off just replacing it with the stock incandescent.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:30 AM
