| mepstein |
Nov 12 2016, 06:17 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,942 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
We have 20 bad ecu's (3.2 engine computers) in the shop. I sent a couple to Steve Wong / 911 Chips for repair. He asked if they were from a 914-6 conversion car since they had a particular defective part. They weren't but most of our cars are 3.2's into early 911's so sort of the same idea. Steve said the reason we were blowing ecu's is because we were mixing the ecu's with a non 3.2 tach. It's very common for a 914 conversion to either modify their 4 tach with an electronic unit or modify an early tach to work with the 3.2. Steve said it may work for a short time, sometimes longer but failure often happens at high rpm. Go to the track, ralley or just some spirited driving and the higher rpm's kill the ecu's. I have to believe him since we have a pile of them to prove it. We had one burn out after 1.5 miles. Even hooking up the shift light wire on the 3.2 tach incorrectly will burn up the ecu's. Not right away but over time. A rebuilt ecu runs $900 and the burnt core is worthless. It's a known problem so it isn't accepted by most, if not all of the ecu rebuilders. You also must use a coil for a 3.2. No substitutes. All of this was unknown to me and the guys at my shop until today but you can be sure they will be more careful about this in the future. 1 more thing and it's something we did already know and practice, always remove the battery terminal from the battery when connecting your ecu.
| Steve |
Nov 13 2016, 02:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,096 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Interesting..... luckily I bought a 3.2 tach by accident when I installed my 2.7 back in 86. So when I upgraded to a 3.2, it worked like a charm. All my gauges are 3.2 gauges.
mepstein 3.2 conversion cars Nov 12 2016, 06:17 PM
JmuRiz VERY good info, thanks for sharing! Nov 12 2016, 06:29 PM
tygaboy Another example of the awesomeness of 914 World me... Nov 12 2016, 06:38 PM
ConeDodger :WTF: Nov 12 2016, 06:40 PM
My 914 Wow, this isn't something I would have thought... Nov 12 2016, 07:03 PM
Wow, this isn't something I would have though... Nov 12 2016, 07:23 PM
jim_hoyland Very interesting; any 3.2 914 owners experience th... Nov 12 2016, 08:25 PM
ConeDodger
Very interesting; any 3.2 914 owners experience t... Nov 12 2016, 09:46 PM
My 914 I also wonder if it would be a similar issue with ... Nov 12 2016, 08:28 PM
I also wonder if it would be a similar issue with... Nov 12 2016, 08:50 PM
jd74914 Interesting. Stock tach (or modified stock, etc.) ... Nov 12 2016, 08:58 PM
Mueller Can't open it up and see what component let th... Nov 13 2016, 03:19 AM
shoguneagle I am with Mike on this one: Opening up the compon... Nov 13 2016, 05:26 AM
I am with Mike on this one: Opening up the compo... Nov 13 2016, 06:06 AM
396 First, thanks for the info with these 3.2 conversi... Nov 13 2016, 07:39 AM
bdstone914
First, thanks for the info with these 3.2 convers... Nov 13 2016, 09:09 AM
mepstein Steve is one of the guru's on this kind of stu... Nov 13 2016, 10:01 AM
forrestkhaag As I am getting closer to installation of the 3.0,... Nov 13 2016, 10:18 AM
jim_hoyland I just ran this by Brian Farmer at Einmalig in Hun... Nov 13 2016, 11:53 AM
Marv's3.6six Interesting... wow.
I had a weird tach issue tha... Nov 13 2016, 12:13 PM
396
Interesting... wow.
I had a weird tach issue th... Nov 13 2016, 01:58 PM
mb911 So the question I have is what are people I swing ... Nov 13 2016, 12:23 PM
porschetub Isn't one tach electronic (3.2) and all the ol... Nov 13 2016, 04:22 PM
Marv's3.6six
My understanding is with a 3.6, sometimes a 3.2 w... Nov 13 2016, 05:12 PM
914dave Mark
Thanks for the heads up. Just drug out my da... Nov 13 2016, 07:51 PM
larryM WOW - thanks!
curiously - Steve never raised ... Nov 16 2016, 05:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st October 2026 - 12:41 PM |
