New member |
New member |
ricardo |
Nov 9 2016, 10:55 AM
Newbie Group: Members Posts: 47 Joined: 9-November 16 From: Lakeview, NY Member No.: 20,572 Region Association: North East States |
New to this site and not sure what I am doing or how to post a problem
timothy_nd28 |
Nov 15 2016, 10:35 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Glad you got it running. Using a file will remove the thin platinum coating on the points, which will only cause them to pit. It's a great temporary band aid, but you really need to replace them.
Before jumping to the next problem, you should address the ignition side by doing a tune up. New points, condenser, set the dwell, replace the cap and rotor and plugs. Then you should attach a fuel pressure gauge to the fuel rail, this may reveal low fuel pressure due to a plugged fuel sock inside the fuel tank or the fuel filter itself or maybe both. Removing the vacuum line to the fuel regulator will simulate wide open throttle, which causes the fuel pressure regulator to not shunt fuel to the return line. With the vacuum line attached, and vacuum present, fuel pressure is reduced. If the car stay's running only with the vacuum line off, kinda tells me that you have a problem with fuel delivery. But, if you have the incorrect dwell angle, you car will also stumble when the RPM's raise. It's good to be thorough, so lets cross off the ignition side first. Also, you really need to replace the plastic fuel lines. With the age of this car, they are very brittle and is a ticking time bomb. They sell a stainless steel version that you should really consider buying. Best of luck |
Lo-Fi Version | Time is now: 9th June 2024 - 08:52 PM |
