> How do you prep Restoration Design parts for paint?
stevegm
post Nov 19 2016, 06:36 PM
Anybody know how to prep Restoration Dedign parts for paint? I have some rocker covers I want to paint tomorrow. I think they are galvannealed. I am not sure if they need to be sanded.
Mark Henry
post Nov 19 2016, 10:28 PM
that's what I do!
You are supposed to be able to degrease and go, at most I'd hit it with a scotchbrite pad only.
stevegm   How do you prep Restoration Design parts for paint?   Nov 19 2016, 06:36 PM
914_teener   Anybody know how to prep Restoration Dedign parts...   Nov 19 2016, 06:57 PM
Mark Henry   You are supposed to be able to degrease and go, at...   Nov 19 2016, 10:28 PM
Rand   Galvanized? Are RD parts galvanized? Whatever, j...   Nov 19 2016, 10:40 PM
Mark Henry   Galvanized? Are RD parts galvanized? Whatever, ...   Nov 19 2016, 11:10 PM
restore2seater   OK, did a quick google search on galvannealed stee...   Nov 20 2016, 12:06 AM
jmitro   yes it is a problem to weld. I've welded the R...   Nov 20 2016, 12:41 AM
mgp4591   yes it is a problem to weld. I've welded the ...   Nov 20 2016, 03:55 AM
jmitro   So take your sanding pad on your small grinder to...   Nov 20 2016, 08:14 AM
Mikey914   Also make sure it's well ventilated when you w...   Nov 20 2016, 03:10 AM
doug_b_928   I'm guessing that it's still best practice...   Nov 20 2016, 07:09 AM
Mark Henry   Truthfully, the young lad has a whole bunch of RD ...   Nov 20 2016, 08:10 AM
Garland   Fine Scotch-bright and surface cleaner for paint, ...   Nov 20 2016, 10:33 AM
bulitt   Pretty cool R&D thread. 4th post from top pg 3...   Nov 20 2016, 08:47 PM
peteyd   Prepping for paint is not any different because of...   Nov 21 2016, 07:31 AM
mb911   I would also put a plug in for a small respirator ...   Nov 21 2016, 08:42 AM
jd74914   I would also put a plug in for a small respirator...   Nov 21 2016, 09:39 AM
restore2seater   Pete, Do you prep the parts you make before weldi...   Nov 21 2016, 09:54 AM
jmitro   another question for Pete..... does the coating d...   Nov 21 2016, 11:11 AM
Mikey914   It may have some variation, but I suspect that the...   Nov 21 2016, 11:27 AM
peteyd   Suppliers of our steel are located in the US. Th...   Nov 21 2016, 12:13 PM
- Lo-Fi Version Time is now: 5th July 2025 - 09:20 PM
