> How do you prep Restoration Design parts for paint?
stevegm
post Nov 19 2016, 06:36 PM
Anybody know how to prep Restoration Dedign parts for paint? I have some rocker covers I want to paint tomorrow. I think they are galvannealed. I am not sure if they need to be sanded.
restore2seater
post Nov 21 2016, 09:54 AM
Future 914 copilot.
Pete,
Do you prep the parts you make before welding?
I've googled how to weld galvanized metal. Most recommend grinding off the layer and some use an acid to remove . I've watched a couple of your videos and can't tell if you are doing any thing prior to welding.
Thanks for all your effort in making these parts for us. With people like you and Mark (Mikey914) the 914 community can have confidence that what you manufacture will be 100% quality when we buy from you. (IMG:style_emoticons/default/first.gif)
Pat
stevegm   How do you prep Restoration Design parts for paint?   Nov 19 2016, 06:36 PM
914_teener   Anybody know how to prep Restoration Dedign parts...   Nov 19 2016, 06:57 PM
Mark Henry   You are supposed to be able to degrease and go, at...   Nov 19 2016, 10:28 PM
Rand   Galvanized? Are RD parts galvanized? Whatever, j...   Nov 19 2016, 10:40 PM
Mark Henry   Galvanized? Are RD parts galvanized? Whatever, ...   Nov 19 2016, 11:10 PM
restore2seater   OK, did a quick google search on galvannealed stee...   Nov 20 2016, 12:06 AM
jmitro   yes it is a problem to weld. I've welded the R...   Nov 20 2016, 12:41 AM
mgp4591   yes it is a problem to weld. I've welded the ...   Nov 20 2016, 03:55 AM
jmitro   So take your sanding pad on your small grinder to...   Nov 20 2016, 08:14 AM
Mikey914   Also make sure it's well ventilated when you w...   Nov 20 2016, 03:10 AM
doug_b_928   I'm guessing that it's still best practice...   Nov 20 2016, 07:09 AM
Mark Henry   Truthfully, the young lad has a whole bunch of RD ...   Nov 20 2016, 08:10 AM
Garland   Fine Scotch-bright and surface cleaner for paint, ...   Nov 20 2016, 10:33 AM
bulitt   Pretty cool R&D thread. 4th post from top pg 3...   Nov 20 2016, 08:47 PM
peteyd   Prepping for paint is not any different because of...   Nov 21 2016, 07:31 AM
mb911   I would also put a plug in for a small respirator ...   Nov 21 2016, 08:42 AM
jd74914   I would also put a plug in for a small respirator...   Nov 21 2016, 09:39 AM
restore2seater   Pete, Do you prep the parts you make before weldi...   Nov 21 2016, 09:54 AM
jmitro   another question for Pete..... does the coating d...   Nov 21 2016, 11:11 AM
Mikey914   It may have some variation, but I suspect that the...   Nov 21 2016, 11:27 AM
peteyd   Suppliers of our steel are located in the US. Th...   Nov 21 2016, 12:13 PM
- Lo-Fi Version Time is now: 5th July 2025 - 09:45 PM
