> Static timing question
ricardo
post Nov 24 2016, 10:49 AM
I'm trying to set the initial timing on my car prior to setting dwell and adjust using strobe light.
What is the easiest way to turn the engine over to static time everything?
ricardo
post Nov 25 2016, 02:24 PM
Removed distributor and replaced points and condenser. Now i'm trying to static set the timing using a test light on the primary distributor and rotating the distributor.
The test light does not light even when I rotate the dist. about 60 degrees.
Any answers
stugray
post Nov 25 2016, 04:51 PM
QUOTE(ricardo @ Nov 25 2016, 01:24 PM) *
Any answers
The test light + should be connected to the neg side of the coil opposite the IGN wire.
This is the same terminal on the coil that the points wire goes to.
The test light - is connected to engine case ground
When the points are open the light should come on
When the points are closed, the light should go off.
If you have the light connected right and it is not turning ON, then the points are closed all the time.
If you did not get the base of the points engaged correctly with the base of the dizzy, they might not be sitting correctly.
Take the cap off and watch while you do this.
You dont need the cap or any of the coil wires to do this test.
If you put the test light + on the IGN side of the coil, does it turn on?
- Lo-Fi Version Time is now: 10th December 2025 - 07:42 AM
