> Static timing question
ricardo
post Nov 24 2016, 10:49 AM
I'm trying to set the initial timing on my car prior to setting dwell and adjust using strobe light.
What is the easiest way to turn the engine over to static time everything?
ricardo
post Nov 26 2016, 11:07 AM
Could someone send me a picture of what their car looks like when you look in the access hole in the blower housing to check for TDC.
I rotate the engine around the area for #1 cylinder firing but I see no mark to line up with notch.
stugray
post Nov 26 2016, 01:25 PM
QUOTE(ricardo @ Nov 26 2016, 10:07 AM) *
The fan probably does not have a TDC mark.
The flywheel does though.
Here's a vid to show where you can see that mark:
https://youtu.be/QtPd5qzyTk8
I use it for timing and setting my valves and never use the fan marks.
- Lo-Fi Version Time is now: 10th December 2025 - 07:40 AM
