| porschetub |
Nov 30 2016, 11:56 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,193 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I know I know the six sounds great in a 914 but I would like to calm the noise a little inside the car.
Is it possible to fit 5mm thick sound deadening under the backpad? I already have the factory tarboard ? in place so not sure if theres room. |
| matthepcat |
Nov 30 2016, 11:59 AM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Yes, you should be able to depending on how you attach it to the firewall. It will probably not quiet it much, as much of the sound comes through the window.
Do you have a firewall pad on the engine side? |
porschetub Extra firewall insulation? Nov 30 2016, 11:56 AM
snakemain Put dynamat (and/or a similar product) on the back... Nov 30 2016, 12:08 PM
gcrotvik
I know I know the six sounds great in a 914 but I... Nov 30 2016, 12:08 PM
JmuRiz Also make sure the lower butyl tape seal on the re... Nov 30 2016, 02:01 PM
Chris914n6 I found under the seats help. Evidently sound boun... Nov 30 2016, 02:51 PM
porschetub Ok,thanks for the replies, lots of info,I recently... Dec 1 2016, 12:40 AM
black73 Firewall Heat-Sound Reduction Mat Dec 1 2016, 05:50 AM
Jgilliam914 I knew a guy with a 2.7 and webers maybe PMO... Dec 1 2016, 12:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 04:49 AM |
