| tsvo |
Nov 29 2016, 07:22 AM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
I am looking fsome help. I have a 1973 1.7L. I have replaced the points and wires as well as general tune up. It starts fine and seems to idle OK. However after 30 - 45 Min of running it starts to bog down. The car loses power, idle drops then backfires. The car gets a quick power surge at the time of backfiring. THe cycle then repeats. I let the car cool down for a little while and it usually goes away.
Any sugestions? |
| IronHillRestorations |
Nov 29 2016, 05:28 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,929 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Check the MPS, CHT, and the distributor.
I worked on a car that had a similar problem, when it got hot the advance plate in the distributor wouldn't move freely. |
| tsvo |
Nov 30 2016, 02:08 PM
tsvo Bog down after warm up Nov 29 2016, 07:22 AM
76-914 Did you replace the condenser also. Have you check... Nov 29 2016, 10:12 AM
tsvo
Did you replace the condenser also. Have you chec... Nov 29 2016, 12:39 PM
BeatNavy Fuel injection or carbs? Initial thought is you... Nov 29 2016, 10:54 AM
tsvo
Fuel injection or carbs? Initial thought is you... Nov 29 2016, 12:38 PM
rmital
.... If FI, there are a couple of potential cause... Nov 29 2016, 01:17 PM
tsvo
.... If FI, there are a couple of potential caus... Nov 30 2016, 06:47 AM
BeatNavy
I worked on a car that had a similar problem, whe... Nov 29 2016, 06:40 PM
BeatNavy Be methodical and follow the directions on that li... Nov 30 2016, 06:58 AM
tsvo
Be methodical and follow the directions on that l... Nov 30 2016, 02:10 PM
Ansbacher Had similar problem and turned out to be bad coil.... Nov 30 2016, 11:23 AM
tsvo
Had similar problem and turned out to be bad coil... Nov 30 2016, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 09:20 PM |
