> Fuel pressure regulator, Where to locate in engine bay
North Coast Jim
post Nov 30 2016, 05:11 PM
My new 2056 engine running 44IDFs has now about a 40 miles on it. So cool to have this car back on the road after 25 years. Runs way to rich with a 160 main, 175 air correction, 60 Idle jets and a 36mm venturi. Continue to have a problem with popping through the carburetor at partial throttle. Fuel pump is the Carter rotary with inline filter along with their SS lines through the tunnel purchased from Tangerine Racing. Engine builder wants me to install a fuel pressure regulator to eliminate this as a variable. The jetting exercise can come afterward. I bought an Italian made "Petrol King" diaphram regulator with single outet. Will hook up serially the pump/ filter/ regulator / guage than "T" off to the two carbs. I'd like to hard mount this device but where ?? To the body or to the engine ?? I'm sure this has been done before. Any suggestions. Pics would also help. Thanks World
jmill
post Dec 2 2016, 09:46 AM
Green Hornet
This is where I start for engines in 2.0 - 2.5 liters with a 2.00 AC jet. Yes, they can fall out of the range below but chances are good that it'll be close to it. There are a ton of variables. ET also plays a big factor.
32mm vent = 115 to 130
34mm vent = 125 to 140
36mm vent = 135 to 165
You may find that the 145 mains are too large for 32mm vents. The smaller the vent, the higher the air velocity passing through it. The higher the velocity the lower the pressure. The lower the pressure the more fuel that will be drawn from the mains.
- Lo-Fi Version Time is now: 1st May 2026 - 10:39 AM
