| oakdalecurtis |
Dec 3 2016, 02:30 AM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,400 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I've owned my '76 teener for about twenty years. I recently installed BlazeCut in the engine compartment to hopefully stop any potential engine fire.
I took the car out for a short test ride soon after completing the BlazeCut install. As I was headed back toward home, suddenly thick black smoke started pouring out from under the dash in front of my left leg! I quickly pulled over and shut the car down before a fire started. After the smoke stopped and my heart slowed down, I lowered the relay panel and here's what I saw! After forty years, one of the of the relay bases somehow short circuited internally and melted the surrounding rubber. I finally got the car home and repaired the melted relay base and all is good now. But I remember what I was thinking when I first saw all that black smoke coming from under the dash. "Great, I have a fire suppression system mounted right behind my back, and the car is going to burn up in front of me in the passenger compartment and there's nothing I can do about it!". I now carry a small fire extinguisher in my center console box, just in case! |
| Mikey914 |
Dec 3 2016, 10:47 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I'd stick to a fire extinguisher on this one. The blaze cut hat to have a significant amount of heat (think damage) before the plastic shell melts. It's a last ditch effort to control the fire. You should always carry a fire extinguisher. Preferably not a dry chemical one as you'll have to disassemble everything if you use one of those as the chemical is bad for your engine.
oakdalecurtis Fireproofed the engine Dec 3 2016, 02:30 AM
cuddyk Wow. Glad you're safe!
I'd be a littl... Dec 3 2016, 09:13 AM
Bartlett 914 Wow! That was one lucky save. Good you got it ... Dec 3 2016, 09:15 AM
PanelBilly Stuffing a blazecut up inside the dash wouldn... Dec 3 2016, 09:38 AM
cary Which relay was it ? Dec 3 2016, 10:03 AM
oakdalecurtis
Thanks for everyone's k... Dec 3 2016, 10:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 02:49 AM |
