| Kent |
Dec 20 2008, 11:39 PM
Newbie ![]() Group: Members Posts: 1 Joined: 20-December 08 From: Virginia Member No.: 9,865 Region Association: MidAtlantic Region |
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
| jdahl |
Dec 3 2016, 10:47 AM
Newbie ![]() Group: Members Posts: 10 Joined: 16-September 10 From: Peoria, IL Member No.: 12,179 Region Association: Upper MidWest |
Need some help here, I've tried Dr. Evil and Racer Chris' methods. I've marked the shift rod and rotated spline by spline. I can get R-3 or 2-5, but not R-5. Any help would be appreciated.
| ChrisFoley |
Dec 3 2016, 03:01 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Kent Gear shift adjustment Dec 20 2008, 11:39 PM
Racer Chris With the trans in neutral, attach a bungee from th... Dec 21 2008, 12:06 AM
jim_hoyland
With the trans in neutral, attach a bungee from t... Feb 1 2014, 09:42 PM
Racer Chris
With the trans in neutral, attach a bungee from ... Feb 2 2014, 08:33 AM
Bruce Hinds
With the trans in neutral, attach a bungee from t... Aug 19 2025, 03:46 PM
Joe Ricard Damn I have been screwing around with "one sp... Dec 24 2008, 09:02 PM
cpavlenko :shock1: :shock1: :shock1: that is so simple, I... Mar 11 2014, 10:06 PM
Red72 A bit of a ressurection here, but I'm having s... May 18 2015, 05:57 PM
tomrev
A bit of a ressurection here, but I'm having ... May 18 2015, 06:44 PM
Red72
A bit of a ressurection here, but I'm having... May 21 2015, 12:01 PM
stugray Another trick I have learned (even if using Racer ... May 21 2015, 12:21 PM
Red72 So I'm now back to a point where I have first ... May 24 2015, 04:58 PM
Dr Evil Nope. The 4-5, 2-3 throws on a properly adjusted b... May 25 2015, 09:05 PM
Hine62 Where is the adjustment screw? I think R & 1st... Jun 8 2015, 01:11 PM
stugray
Where is the adjustment screw? I think R & 1s... Jun 8 2015, 05:06 PM
rgalla9146 Mark both pieces with a fine tip magic marker
put... Jun 8 2015, 06:37 PM
db9146 So mine is a tailshifter and I just finished repla... Jun 8 2015, 08:42 PM
Dave_Darling Sounds like you may need to adjust the lever over ... Jun 8 2015, 08:58 PM
RobW I use the put it wrong method, and then estimating... Jun 9 2015, 07:43 AM
Racer Chris
I use the put it wrong method, and then estimatin... Jun 9 2015, 08:48 AM
Dr Evil Put in 2nd. Disconnect shifter at rod (side shift)... Jun 9 2015, 07:42 PM
Bruce Hinds
Put in 2nd. Disconnect shifter at rod (side shift... Aug 19 2025, 08:48 PM
SKL1 Get Chris' new front adjuster... just a satis... Dec 3 2016, 12:30 PM
Keith914 Check that nothing is preventing full left to righ... Dec 3 2016, 02:03 PM
Dave_Darling
Check that nothing is preventing full left to rig... Aug 19 2025, 07:07 PM
porschetub I continue to struggle with mine and think I'a... Dec 3 2016, 02:54 PM
Jack Standz There is an access hole towards the rear of the ca... Aug 19 2025, 06:55 PM
Bruce Hinds
There is an access hole towards the rear of the c... Aug 19 2025, 08:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 06:35 PM |
