| tomh |
Dec 3 2016, 04:34 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Reinstalling my center counsel, i have a left over wire and don't know where it goes.
Its black with blue dots and has a very small female spade fitting. Labled all of them and all the bigger fittings seemed to match up . When i ran the car awile the volt gauge worked but the temp never moved. Any ideas? I |
| iankarr |
Dec 3 2016, 05:27 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,603 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Black with blue stripe should be instrument light power. If you've got an additional wire that's black with blue dots, that sounds like the PO added something somewhere.
As for the temp gauge, it takes a while to register. Make sure you've got a good connection to the sender in the taco plate and that the wire is connected securely to the green wire in the protective plastic case under the battery. If all looks good and you still don't get any movement after about 15 minutes of driving, you'll need to check the sender or gauge. Enjoy! |
| TheCabinetmaker |
Dec 3 2016, 10:19 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Black with blue stripe should be instrument light power. If you've got an additional wire that's black with blue dots, that sounds like the PO added something somewhere. As for the temp gauge, it takes a while to register. Make sure you've got a good connection to the sender in the taco plate and that the wire is connected securely to the green wire in the protective plastic case under the battery. If all looks good and you still don't get any movement after about 15 minutes of driving, you'll need to check the sender or gauge. Enjoy! Takes a while to register. Huh? The oil temp gauge registers the instant the key is turned on no matter what the temp. If the oil is cold it registers cold. If the oil is warm it registers warm. Yes, it takes a while for the oil temp to change so the gauge responds accordingly. |
| iankarr |
Dec 3 2016, 10:38 PM
Black with blue stripe should be instrument light power. If you've got an additional wire that's black with blue dots, that sounds like the PO added something somewhere. As for the temp gauge, it takes a while to register. Make sure you've got a good connection to the sender in the taco plate and that the wire is connected securely to the green wire in the protective plastic case under the battery. If all looks good and you still don't get any movement after about 15 minutes of driving, you'll need to check the sender or gauge. Enjoy! Takes a while to register. Huh? The oil temp gauge registers the instant the key is turned on no matter what the temp. If the oil is cold it registers cold. If the oil is warm it registers warm. Yes, it takes a while for the oil temp to change so the gauge responds accordingly. Um, Yeah. |
tomh unknow wire Dec 3 2016, 04:34 PM
SirAndy Sounds like the power for the square defrost indic... Dec 3 2016, 05:40 PM
76-914
Sounds like the power for the square defrost indi... Dec 4 2016, 09:04 AM
tomh Ok, when seats go in next weekend ill be able to d... Dec 3 2016, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th August 2026 - 02:51 PM |
