> Sheet metal help - Need angled flange tool?
3d914
post Nov 6 2016, 12:26 PM
Working on the support frame for my trunk lid so it opens from the back instead of the front. I'm planning on using 14ga steel, but may need to go to 16ga if I can't find a tool for this. Preferably I'd like an angled, not flat, flange. Most the hand or pneumatic tools out there only do a flat flange for like an overlap weld joint. Anyone seen or used a hand (pneumatic) tool with something other than a flat flange?
Here's the drawing for the support frame (in orange). They'll plasma cut the pieces for me, so I need to find a method to flange these cutouts that lighten the piece, to add the strength back in.
If I can't find a hand tool for this, I'll need to go with a press and some hole flange tools - but those I can add without having these shapes pre-cut.
3d914
post Dec 4 2016, 10:10 AM
Here's what I came up with. Found a 1.5" flange die good up to 16ga. I was able to use it to get the angled flange I needed. Worth the $40
3d914   Sheet metal help - Need angled flange tool?   Nov 6 2016, 12:26 PM
McMark   A bead roller might be able to do what you need, b...   Nov 6 2016, 01:54 PM
3d914   A bead roller might be able to do what you need, ...   Nov 6 2016, 05:59 PM
McMark   With all the pneumatic flange tools out there, yo...   Nov 7 2016, 11:39 AM
914forme   With all the pneumatic flange tools out there, y...   Nov 7 2016, 01:28 PM
dlee6204   So what are the internal cutouts for? Weight savi...   Nov 6 2016, 06:12 PM
3d914   So what are the internal cutouts for? Weight sav...   Nov 14 2016, 07:03 PM
914forme   Hammer forming them is the best way to do them as ...   Nov 6 2016, 07:00 PM
914_teener   Hammer forming them is the best way to do them as...   Nov 7 2016, 11:01 AM
mbseto   :agree: Hammer form using McMark's wooden bu...   Nov 7 2016, 10:45 AM
Valy   Not sure how much reinforcing you need but this ma...   Nov 7 2016, 11:13 AM
rick 918-S   I think I used Plywood as a buck for this panel. I...   Nov 7 2016, 03:51 PM
3d914   I think I used Plywood as a buck for this panel. ...   Nov 14 2016, 07:07 PM
rick 918-S   I think I used Plywood as a buck for this panel....   Nov 15 2016, 07:26 AM
914_teener   Rick....nice work. Never forget you and Mark work...   Nov 7 2016, 04:21 PM
tygaboy   If you're not stuck on those cut out shapes, y...   Nov 14 2016, 07:13 PM
3d914   If you're not stuck on those cut out shapes, ...   Nov 16 2016, 07:51 AM
mbseto   This is a mini-clinic.   Nov 15 2016, 10:25 AM
3d914   Rick, your example makes sense, and thanks for sha...   Nov 16 2016, 08:06 AM
3d914   Here's what I came up with. Found a 1.5" ...   Dec 4 2016, 10:10 AM
Catorse   Looks great and will be plenty strong. Where did y...   Dec 4 2016, 12:06 PM
- Lo-Fi Version Time is now: 12th June 2026 - 05:55 PM
