question about fittings on original 6 oil tank, oil return fitting |
gereed75 |
Dec 5 2016, 10:05 AM
Senior Member Group: Members Posts: 1,250 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Regarding the oil return line (from the engine scavenge line). The line/hose screws onto a fitting. Does the fitting for this line screw into female threads on the oil tank??
I can see the 32mm hex head on this fitting, but I do not want to put a wrench on it and find that it is welded in and damage the tank. The tank is still in the car. I had it out last year for a paint/refurbish but do not remember exactly the arrangement at that fitting. I would prefer not to have to remove the tank. Thanks |
IronHillRestorations |
Dec 5 2016, 01:10 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The large hex you see is a nut, which is one of three fasteners that secures the tank to the car. That same threaded boss is the where the short flex line that goes through the left engine shelf attaches. Do a search on 914-6 oil tank diagram, and you find what you need.
Regarding the oil return line (from the engine scavenge line). The line/hose screws onto a fitting. Does the fitting for this line screw into female threads on the oil tank?? I can see the 32mm hex head on this fitting, but I do not want to put a wrench on it and find that it is welded in and damage the tank. The tank is still in the car. I had it out last year for a paint/refurbish but do not remember exactly the arrangement at that fitting. I would prefer not to have to remove the tank. Thanks |
mskala |
Dec 5 2016, 01:18 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Not sure what all you are asking, just that you don't want to remove the tank for
whatever other job you are not mentioning. The oil tank lines at the bottom and side are both male. The hoses that attach to these should never need to be removed unless the tank needs to come out. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:38 AM |
