| 80cap |
Dec 5 2016, 01:46 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian |
| Dave_Darling |
Dec 5 2016, 02:18 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
There should be three (possibly four) electrical contacts in the plug for the sender. One will be a ground, one will be for the gauge, and one will be for the warning light. The ground contact should have a "three parallel lines" ground logo; the wire from the light should be labeled "WK", and the wire from the gauge should be labeled "G".
The ground connection would have a brown wire that plugs into it, the warning light a black wire, and the gauge signal a green wire. So, with the sender out of the fuel tank and held upright: - Resistance between WK and ground should be about zero - Resistance between G and ground should be about 70-100 ohms With the sender turned upside down: - Resistance between WK and ground should be infinite (no connection) - Resistance between G and ground should be ~1-10 ohms The float inside the sender should slide up and down relatively freely when the sender is turned upside down and rightside up. --DD |
80cap fuel gauge sender Dec 5 2016, 01:46 PM
80cap Thanks Dave!
Well like most things so far on m... Dec 5 2016, 03:07 PM
914Bryan Does anyone have pictures of this? Dec 6 2016, 10:03 AM
jim_hoyland :agree: Just went through this. The inside of the... Dec 6 2016, 09:49 PM
Hans Jan Just ran out of gas this evening. The reserve ligh... Jan 25 2017, 09:59 PM
Dave_Darling The warning light contacts are on the same float a... Jan 25 2017, 10:29 PM
Hans Jan
The warning light contacts are on the same float ... Jan 25 2017, 10:52 PM
bdstone914
The warning light contacts are on the same float... Jan 26 2017, 09:42 AM
seatosummit
[quote name='Hans Jan' post='2448102' date='Jan 2... Jul 20 2021, 10:55 PM
Dave_Darling
I will start looking for a new/used gauge.
I su... Jan 26 2017, 02:23 PM
fixer34
The warning light contacts are on the same float ... Feb 12 2017, 02:14 PM
Hans Jan Have not yet figured out how to read the resistanc... Jan 26 2017, 06:51 PM
Hans Jan See pic Jan 26 2017, 06:51 PM
Dave_Darling One of the three pins is ground, one is the signal... Jan 26 2017, 10:50 PM
Hans Jan After removing I find the following readings:
Upsi... Jan 27 2017, 03:10 PM
Dave_Darling We had similar trouble when we bought the wife... Feb 12 2017, 09:15 PM
914Sixer Take the sending unit and let it soak in a some la... Feb 12 2017, 09:57 PM
forrestkhaag For what it is worth, I had to open my sender tube... Feb 13 2017, 11:52 AM
Costa05
For what it is worth, I had to open my sender tub... Nov 30 2020, 11:46 PM
Red76 The real thin wires on the outside edges of the fl... Nov 3 2017, 02:11 PM
neilbardsley I'm having a problem with my fuel sender/gauge... Apr 13 2021, 01:39 PM
Retroracer So that would point to either wiring or gauge bein... Apr 13 2021, 02:25 PM
neilbardsley
So that would point to either wiring or gauge bei... Apr 14 2021, 12:50 AM
Cairo94507 I just replaced my fuel sender. It was sticking a... Apr 14 2021, 07:17 AM
neilbardsley Ok. It's not the wiring. 1 ohms resistance o... Apr 16 2021, 01:21 PM
euro911 Here's a good thread on testing and refurbishi... Apr 16 2021, 02:07 PM
neilbardsley
Here's a good thread on testing and refurbish... Apr 16 2021, 02:51 PM
Retroracer Neil - so it does sound like a sender issue. Pres... Apr 16 2021, 04:50 PM
neilbardsley Thank you. Yes connecting directly to ground move... Apr 16 2021, 11:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 02:57 PM |
