fuel gauge sender, Bench testing |
80cap |
Dec 5 2016, 01:46 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian |
Dave_Darling |
Dec 5 2016, 02:18 PM
There should be three (possibly four) electrical contacts in the plug for the sender. One will be a ground, one will be for the gauge, and one will be for the warning light. The ground contact should have a "three parallel lines" ground logo; the wire from the light should be labeled "WK", and the wire from the gauge should be labeled "G".
The ground connection would have a brown wire that plugs into it, the warning light a black wire, and the gauge signal a green wire. So, with the sender out of the fuel tank and held upright: - Resistance between WK and ground should be about zero - Resistance between G and ground should be about 70-100 ohms With the sender turned upside down: - Resistance between WK and ground should be infinite (no connection) - Resistance between G and ground should be ~1-10 ohms The float inside the sender should slide up and down relatively freely when the sender is turned upside down and rightside up. --DD |
Lo-Fi Version | Time is now: 1st June 2024 - 05:21 AM |
