question about fittings on original 6 oil tank, oil return fitting |
gereed75 |
Dec 5 2016, 10:05 AM
Senior Member Group: Members Posts: 1,250 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Regarding the oil return line (from the engine scavenge line). The line/hose screws onto a fitting. Does the fitting for this line screw into female threads on the oil tank??
I can see the 32mm hex head on this fitting, but I do not want to put a wrench on it and find that it is welded in and damage the tank. The tank is still in the car. I had it out last year for a paint/refurbish but do not remember exactly the arrangement at that fitting. I would prefer not to have to remove the tank. Thanks |
gereed75 |
Dec 5 2016, 04:09 PM
yep, I was able to do some work this afternoon and found that that fitting is a welded in nipple with a retention nut that helps hold the tank in the car.
I am ordering fittings for an oil cooler set up. Any one know the thread size on that nipple?? I am thinking 26 x 1.25 Thanks |
mb911 |
Dec 5 2016, 04:56 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
yep, I was able to do some work this afternoon and found that that fitting is a welded in nipple with a retention nut that helps hold the tank in the car. I am ordering fittings for an oil cooler set up. Any one know the thread size on that nipple?? I am thinking 26 x 1.25 Thanks How does it hold the tank in the car? I have never seen that on any of the 6 tanks I have ever seen. The 8mm studs are the only thing that holds them in the car.. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:31 AM |
