Found 914/6 Value Help Please |
Karguy12 |
Dec 8 2016, 10:04 PM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I am no Porsche expert although I have owned a few over the years. Ran across a 914 in a warehouse that is supposedly a 914/6. It has a 914/6 VIN stamped into the front right apron that looks factory (914043xXXX) The engine numbers match, trans numbers match and it has all of the 914/6 details that I could find like five bolt Fuchs, correct gauges, ignition, wiring harness, engine mounts, oil cooler, rear valance, etc. But the owner says he does not think it is a real 914/6 car. It has been in the warehouse for over 30 years and needs restoration but it is a very solid and straight car.
Engine is out as is the trans. The rear fuchs are a little wider than the fronts. The owner is asking me to make him an offer. So what I need to know is a. What is this car worth if it has ALL of the 914/6 stuff and it is NOT a real car?, and b. What would it be worth in this condition if it WAS a real car? Attached image(s) |
GeorgeRud |
Dec 9 2016, 09:50 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
That's a 1970 VIN, so it should have non-retractable seat belts, a field passenger seat, and no flat metal circular support around the front spare tire. Check the VIN on the windshield pillar as well. The ignition key should be on the left of the steering column.
There's nothing bad about a converted six, in fact they're actually a better car due to the many updates that most owners have made. However, if the VIN has been tampered with, run away as fast as you can or you'll be facing legal troubles down the road! |
Lo-Fi Version | Time is now: 7th June 2024 - 03:11 PM |
