Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
porschetub |
Dec 12 2016, 12:25 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Test thermostat before installing if not new,check condition of cable roller,make sure the pivot bushes for the flaps inside the fan housing aren't causing any binding,the whole system needs to move freely.
Lastly, the cable must be adjusted correctly on the air flap clamp. The whole cooling system function on T4/T1 engines is often misunderstood or ignored completely by many.....big mistake. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:28 PM |
