Found 914/6 Value Help Please |
Karguy12 |
Dec 8 2016, 10:04 PM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I am no Porsche expert although I have owned a few over the years. Ran across a 914 in a warehouse that is supposedly a 914/6. It has a 914/6 VIN stamped into the front right apron that looks factory (914043xXXX) The engine numbers match, trans numbers match and it has all of the 914/6 details that I could find like five bolt Fuchs, correct gauges, ignition, wiring harness, engine mounts, oil cooler, rear valance, etc. But the owner says he does not think it is a real 914/6 car. It has been in the warehouse for over 30 years and needs restoration but it is a very solid and straight car.
Engine is out as is the trans. The rear fuchs are a little wider than the fronts. The owner is asking me to make him an offer. So what I need to know is a. What is this car worth if it has ALL of the 914/6 stuff and it is NOT a real car?, and b. What would it be worth in this condition if it WAS a real car? Attached image(s) |
carr914 |
Dec 9 2016, 07:48 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I see that it has a 914-4 engine lid drip pan. I'm not sure where you are in Florida, but Steve & I are in Tampa. Not trying to brag, but I would say that we have a Expert Opinion on 914-6s. We are willing to help without undermining any deal you might have. I might even know of the car! |
Karguy12 |
Dec 9 2016, 08:07 PM
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything.
Dave_Darling |
Dec 9 2016, 10:04 PM
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything. Not much--EXCEPT to someone with the 914-6 that it came out of. (Worth somewhere in between to someone with a 914-6 wanting an engine/trans at least of the correct type.) The 914-6 motor was basically a 1969 911T motor, AKA the wimpiest 911 motor ever produced. And a rebuild on it is nearly as expensive as a rebuild on a much higher-powered and better-regarded engine, so demand for them is relatively low. --DD |
mepstein |
Dec 10 2016, 07:15 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything. Not much--EXCEPT to someone with the 914-6 that it came out of. (Worth somewhere in between to someone with a 914-6 wanting an engine/trans at least of the correct type.) The 914-6 motor was basically a 1969 911T motor, AKA the wimpiest 911 motor ever produced. And a rebuild on it is nearly as expensive as a rebuild on a much higher-powered and better-regarded engine, so demand for them is relatively low. --DD About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. |
Karguy12 |
Dec 10 2016, 08:21 AM
QUOTE About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. So based on this, if the car is NOT real, I've got about $10,000 in 914/6 parts (engine trans and suspension), and maybe $2,000-$4,000 in a parts car with the wheels? So around $12,000 conservatively? Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. |
orthobiz |
Dec 16 2016, 04:56 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. I rammed into someone in the 80's with my totaled 914 and the transmission mounts broke off... Paul |
Unobtanium-inc |
Dec 16 2016, 08:46 AM
Advanced Member Group: Members Posts: 2,213 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. I rammed into someone in the 80's with my totaled 914 and the transmission mounts broke off... Paul This 356A was hit very hard in the rear, it broke the ears off the gearbox. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:53 AM |
