> Tires and pressure
lsintampa
post Dec 23 2016, 10:16 AM
Here goes, maybe I'm not understanding something and there is opportunity for me to learn.
Firstly, what happened to the "tire calculator"?
Now onto the discussion. Porsche 914's for the most part call for tire pressures to be about 23PSI front and 26PSI rear. I may be off some, but for "most" 914's I think those numbers to be "horseshoe" close enough.
BUT, wouldn't one think that the PSI for the car is based on the tire size that came on the car?
IDK, but I would put some big bucks on the fact that most of us are NOT running on stock wheels / tire combination.
So I wonder for my setup - I'm running Yoko Avid envigor's 195/65/15's on 15X6 cookie cutters - what tire pressure should I be using?
It's just hard for me to understand the relationship between the car / tire size / and tire pressure. IE, if I put that same tire on a different car - would that car's recommended pressure be different?
Enlighten me please.
Thanks,
Len
PS - I wish you all a joyous holiday season and may we all enjoy a healthy new year!
(IMG:style_emoticons/default/wreath.gif)
brant
post Dec 23 2016, 10:34 AM
23psi sounds way to low, even for stock
that is a pressure that a person would run on the race track with a tire specifically built to have a stiff side wall
its too low for a street tire side wall
I usually run 30 or 32 on street tires of non stock size
I'm not fully aware of how the car weight interacts with the contact patch and PSI as a variable
but take into account that modern tires are built for modern/heavier cars and that the sidewall construction of how the tire is supported by the air pressure is likely as important as the weight of the car or suspension design
23psi sounds close to dangerous. Hard cornering and a flexible/soft undersupported sidewall could lead to a bead failure (think ford explorer roll overs)
lsintampa   Tires and pressure   Dec 23 2016, 10:16 AM
brant   23psi sounds way to low, even for stock that is a...   Dec 23 2016, 10:34 AM
mepstein   Everything is a relationship. Size, type, weight, ...   Dec 23 2016, 10:37 AM
Tom_T   Hi Len, There was some Java script issue with the...   Dec 23 2016, 11:42 AM
walterolin   FWIW the 1971 owner's manual and the 914 Porsc...   Dec 23 2016, 12:45 PM
lsintampa   OK thanks all, I did learn something - so that...   Dec 23 2016, 02:02 PM
Cairo94507   Given the size of some of the pot holes on the roa...   Dec 23 2016, 02:06 PM
lsintampa   Given the size of some of the pot holes on the ro...   Dec 23 2016, 02:52 PM
euro911   ... I'm in Tampa.... Pot holes? We don...   Dec 24 2016, 01:35 AM
michael7810   Sorry for the highjack...but just how does one tel...   Dec 23 2016, 02:56 PM
ConeDodger   Sorry for the highjack...but just how does one te...   Dec 23 2016, 03:15 PM
michael7810   Sorry for the highjack...but just how does one t...   Dec 23 2016, 03:40 PM
mgp4591   [quote name='ConeDodger' post='2436870' date='Dec...   Dec 24 2016, 02:16 AM
jim_hoyland   This is on my expaion tank, never went by it after...   Dec 23 2016, 03:16 PM
mepstein   I settled on 28F, 30R with 195x65x15, 2.0 Fuchs on...   Dec 23 2016, 03:36 PM
My 914   I think 30 is an easy number to remember and a goo...   Dec 24 2016, 08:04 AM
Ian Stott   I run 28 psi all around, 205/60. Bridgestone Poten...   Dec 25 2016, 06:36 AM
Geezer914   Firestone Firehawk AS 195/60x15. 26 front, 28 rea...   Aug 25 2023, 01:07 PM
- Lo-Fi Version Time is now: 20th November 2026 - 07:44 AM
