| amfab |
Dec 23 2016, 05:33 PM
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None
Hi, I have a question about treating the inside of the longs. I have some rust issues in the back of the long—jack point areas. I am cutting out and replacing the weak areas.
The area to the front of the jack point has some surface rust, but the metal is solid so I do not want to cut further forward. I am also going to put Brad Mayeurs kit over it all, so I am not worried about strength, I do however want to convert/seal the inside of the long going forward, before I install the kit to prevent further degredation. What is the best/easiest way to do this? I was looking at the Eastwood green aerosol frame stuff, the converter/sealer that has the hose, or maybe Ospho, but I am trying to not damage the heater hoses in there and still get decent coverage. I don't know how to get the aerosol hose up into the long Any suggestions? Can the heater hoses be pulled out and replaced without cutting the inner rocker completely out? What are they made of anyway? Thanks for any suggestions -Andrew |
| jmitro |
Dec 24 2016, 12:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
I used the Eastwood internal frame coating kit also. Three cans.
Even if the longs are closed, you can still insert the nozzle up the drain holes at the bottom of the pinch weld, and you will get good coverage. The coating is very thin so it penetrates very well. |
| amfab |
Dec 24 2016, 01:22 PM
Mike, I plan to pull the two inner long rubber plugs to access the interior and sneak an inspection camera in there to 'see' any obstacles, but from looking at other folk's open longs (repair work), I have a pretty good idea of what's in there. Mark, where are these plugs? That spray won't hurt those tubes Awesome, thanks, I hope that goes for the Ospho too, I try to cover as much of inside of the long with OSPHO. Once it dries, I use the Eastwood internal frame coating. OK I will do both, I have the same dilemma. What about the rusty pieces and scale that are sitting inside the long? Will the spray cover that and "seal" over the loose debris? My guess is no. I had a small rust hole in the passenger side front fender well, right at the end (beginning?) of the long. I opened it up to about a silver dollar size hole, at that point I need to weld in a small patch anyway. What I found was a fair amount of rusty scale. I was able to vacuum a lot of it out and the rest I used a magnet on a stick, then I used air to blow out any residual dust/dirt. I was then able to use the Eastwood green spray. It worked well for me but I had that opening to work with. So now I know the driver side long is also full of debris that I want to remove so I can coat the inside of that long but I don't have any thru rust on that side to break open another hole. I hate to make a hole in a solid section, but……... Hardly any loose stuff where the metal is solid. I also have a small hole at the front of the long I will be repairing also. So I will use that as access as you mentioned I used the Eastwood internal frame coating kit also. Three cans. Even if the longs are closed, you can still insert the nozzle up the drain holes at the bottom of the pinch weld, and you will get good coverage. The coating is very thin so it penetrates very well. Good to know, I just ordered a gallon of Ospho that I will squirt in with a cheap pesticide sprayer, then I will do the Eastwood stuff—I bought 4 cans. Then I will prime and paint the inside of Brad Mayuer kit, then scrape the paint and primer off where it is to be welded and prime with weldable primer. It is now a California car so that should be good for a couple decades Thanks everyone for the advice AND the pictures. |
amfab Treating the longs, advice needed Dec 23 2016, 05:33 PM
GeorgeRud I'd give Brad a call and get his advice as he... Dec 23 2016, 07:18 PM
Elliot Cannon I used some rust treatment stuff on my passenger s... Dec 23 2016, 08:25 PM
rick 918-S That spray won't hurt those tubes Dec 23 2016, 09:11 PM
euro911 Eastwood Internal Frame Coating. I did my tunnel w... Dec 23 2016, 09:20 PM
mgp4591 Is there enough room to get good spray coverage in... Dec 23 2016, 10:19 PM
euro911 Mike, I plan to pull the two inner long rubber plu... Dec 24 2016, 12:16 AM
mgp4591
Mike, I plan to pull the two inner long rubber pl... Dec 24 2016, 02:26 AM
dlee6204 I try to cover as much of inside of the long with ... Dec 24 2016, 04:37 AM
74ravenna I have the same dilemma.
What about the rusty pie... Dec 24 2016, 06:10 AM
cary Here's a shot of the area your trying to tackl... Dec 24 2016, 09:20 AM
BeatNavy And here's what it may look like on the inside... Dec 24 2016, 09:53 AM
tomrev I'v had good luck with the Eastwood spray, bot... Dec 24 2016, 10:01 AM
BeatNavy
You can see the ope... Dec 24 2016, 01:53 PM
amfab Well, as I hack into this looking for clean metal ... Dec 28 2016, 02:37 PM
cuddyk
BTW, I just got an Air Supply system and I am l... Dec 28 2016, 04:34 PM
amfab OMG the driver's side is worse. I could jack u... Dec 29 2016, 10:35 AM
BeatNavy
So regarding my initial post... never mind.
Rest... Dec 29 2016, 10:46 AM
amfab
Res... Dec 30 2016, 11:43 AM
euro911 :agree: whole-heartedly ... Dec 25 2016, 01:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:36 PM |
