> Treating the longs, advice needed
amfab
post Dec 23 2016, 05:33 PM
Hi, I have a question about treating the inside of the longs. I have some rust issues in the back of the long—jack point areas. I am cutting out and replacing the weak areas.
The area to the front of the jack point has some surface rust, but the metal is solid so I do not want to cut further forward. I am also going to put Brad Mayeurs kit over it all, so I am not worried about strength, I do however want to convert/seal the inside of the long going forward, before I install the kit to prevent further degredation.
What is the best/easiest way to do this? I was looking at the Eastwood green aerosol frame stuff, the converter/sealer that has the hose, or maybe Ospho, but I am trying to not damage the heater hoses in there and still get decent coverage. I don't know how to get the aerosol hose up into the long
Any suggestions? Can the heater hoses be pulled out and replaced without cutting the inner rocker completely out? What are they made of anyway?
Thanks for any suggestions
-Andrew
euro911
post Dec 25 2016, 01:23 AM
(IMG:style_emoticons/default/agree.gif) whole-heartedly ...
amfab   Treating the longs, advice needed   Dec 23 2016, 05:33 PM
GeorgeRud   I'd give Brad a call and get his advice as he...   Dec 23 2016, 07:18 PM
Elliot Cannon   I used some rust treatment stuff on my passenger s...   Dec 23 2016, 08:25 PM
rick 918-S   That spray won't hurt those tubes   Dec 23 2016, 09:11 PM
euro911   Eastwood Internal Frame Coating. I did my tunnel w...   Dec 23 2016, 09:20 PM
mgp4591   Is there enough room to get good spray coverage in...   Dec 23 2016, 10:19 PM
euro911   Mike, I plan to pull the two inner long rubber plu...   Dec 24 2016, 12:16 AM
mgp4591   Mike, I plan to pull the two inner long rubber pl...   Dec 24 2016, 02:26 AM
dlee6204   I try to cover as much of inside of the long with ...   Dec 24 2016, 04:37 AM
74ravenna   I have the same dilemma. What about the rusty pie...   Dec 24 2016, 06:10 AM
cary   Here's a shot of the area your trying to tackl...   Dec 24 2016, 09:20 AM
BeatNavy   And here's what it may look like on the inside...   Dec 24 2016, 09:53 AM
tomrev   I'v had good luck with the Eastwood spray, bot...   Dec 24 2016, 10:01 AM
jmitro   I used the Eastwood internal frame coating kit als...   Dec 24 2016, 12:04 PM
amfab   Mike, I plan to pull the two inner long rubber pl...   Dec 24 2016, 01:22 PM
BeatNavy   Mark, where are these plugs? You can see the ope...   Dec 24 2016, 01:53 PM
amfab   Well, as I hack into this looking for clean metal ...   Dec 28 2016, 02:37 PM
cuddyk   BTW, I just got an Air Supply system and I am l...   Dec 28 2016, 04:34 PM
amfab   OMG the driver's side is worse. I could jack u...   Dec 29 2016, 10:35 AM
BeatNavy   So regarding my initial post... never mind. Rest...   Dec 29 2016, 10:46 AM
amfab   So regarding my initial post... never mind. Res...   Dec 30 2016, 11:43 AM
euro911   :agree: whole-heartedly ...   Dec 25 2016, 01:23 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:35 PM
