> Girl Meets Car, A Love Story
memmek2k
post Dec 27 2016, 03:49 PM
My uncle-in-law decided to give us his '73 Porsche 914 1.7L. He said he just didn't have time to work on it or drive it anymore and wanted to see it go to someone that would drive it and take care of it.
Only problem is it didn't run.
He said it last ran about 2.5 years ago, after a major service overhaul at a local VW shop. He was able to go on a few drives, and let it sit for a bit. When he tried to start it again, it wouldn't turn over.
So I spent Christmas weekend intermittently at their house, wrenching and cursing and bleeding (as is the customary ritual when meeting a new car). After determining the ECU's fuel pump circuit is fried, along with the 2.5-year old fuel pump, I decided to hotwire the fuel pump to one of the switched power circuits so we could get it out of the garage and onto a trailer.
"My Porsche's in the Hangar" is not a phrase I ever imagined being able to say. We've been fighting the city to build a garage for the last year due to some bigoted BS in the neighborhood we live in. The original plan was to have a garage in which to put a Porsche by this time. Since there's no garage, we're renting hangar space from my boss, which sort of puts a damper on my ability to wrench freely.
Right now, the current plan is to give everything a refresh/once over and get accustomed to the car. I'm sure it needs new fluids and consumables. Probably could use a valve adjustment and a rear caliper adjustment (they're sticking). It has a high idle, which I'm used to attributing to vacuum leaks on MAF cars, but I'm under the impression the 1.7L has a MAP sensor. Also the driver's outside door handle broke literally right after I fixed the fuel pump, so I need to fix that now, too.
Long term: paint's rough, body has some dings and rust (and I need to examine the hell hole). It'll need more gofast eventually, but doesn't everything? (IMG:style_emoticons/default/biggrin.gif)
Left Side
Right Side
Owner's Final Farewell
Dave_Darling
post Dec 27 2016, 10:18 PM
914 Idiot
Double-check your diagnosis of the ECU. Those are actually pretty robust and not that easy to kill. If the car actually did run with the pump jumpered to switched power, the ECU is very likely fine.
One thing to check is the fuses on the relay board. One of them powers the fuel pump, but I forget which one. Pull them and examine them; these fuses can pop and still look OK until you remove them from their holders. Take the opportunity to clean them up and the fingers that hold them with a wire brush, just to be sure the connection is good.
One interesting thing--in the D-jet cars, the fuel pump is run off the same circuit as the Aux Air Regulator. If the AAR wire shorts to ground, if will blow the fuse and the fuel pump won't run. This has gotten more than a few people over the years.
D-jet usually sees vacuum leaks as just more throttle, so vacc leaks will result in a high idle. Most airflow-measurement type fuel injection systems will have the mixture thrown off by air leaks, though modern ones can correct for that through the O2 sensor circuitry.
For just about all of the D-jet info that is known these days, see: http://members.rennlist.com/pbanders
Pelican Parts has tech articles, including an illustrated one on how to remove the door handle and repair the cam on it which is often the problem.
Good luck with the car!
--DD
memmek2k   Girl Meets Car   Dec 27 2016, 03:49 PM
76-914   :wttc:   Dec 27 2016, 04:20 PM
Tom_T   As Laugh-In's Arte Johnson would say from behi...   Dec 27 2016, 04:23 PM
ClayPerrine   :wttc: There are lots of people with lots of exp...   Dec 27 2016, 06:21 PM
Elliot Cannon   :wttc: There are lots of people with lots of ex...   Dec 28 2016, 11:55 AM
ClayPerrine   :wttc: There are lots of people with lots of e...   Dec 28 2016, 10:24 PM
memmek2k   Yes, she is taller than me. What's your po...   Dec 29 2016, 08:41 AM
bandjoey   Nice Car and Have Fun ! :wttc:   Dec 27 2016, 06:23 PM
ConeDodger   :wttc:   Dec 27 2016, 06:40 PM
Blue6   :wttc: looks like you have a nice starting point.....   Dec 27 2016, 07:43 PM
Rand   He cared for it obviously. Some nice upgrades. The...   Dec 27 2016, 08:06 PM
Robnxious   :wttc: As a new owner myself, welcome to the board...   Dec 27 2016, 08:49 PM
Big Len   Love the dual fog lights.   Dec 27 2016, 09:06 PM
Dave_Darling   Double-check your diagnosis of the ECU. Those are...   Dec 27 2016, 10:18 PM
Mikey914   Congratulations on your 914! Learn as much as ...   Dec 28 2016, 02:49 AM
RobW   :agree: :wttc:   Dec 28 2016, 07:01 AM
malcolm2   I see 914rubber chimed in, but he did not say anyt...   Dec 28 2016, 08:01 AM
memmek2k   Thanks everyone for the warm welcome and the links...   Dec 28 2016, 09:00 AM
Shadowfax   :wttc:   Dec 28 2016, 10:01 AM
green914   :wttc:   Dec 28 2016, 10:42 AM
Dave_Darling   No--with Clay, the point is always to make fun of ...   Dec 29 2016, 06:31 PM
SirAndy   [quote name='memmek2k' post='2438604' date='Dec 29...   Dec 29 2016, 07:20 PM
ClayPerrine   http://www.914world.com/bbs2/uploads_offsite/s2.qu...   Dec 29 2016, 07:27 PM
ConeDodger   http://www.914world.com/bbs2/uploads_offsite/s2.q...   Dec 29 2016, 07:29 PM
ClayPerrine   Not to s t r e t c h this out too far Clay, but ...   Dec 29 2016, 07:44 PM
ConeDodger   Not to s t r e t c h this out too far Clay, but...   Dec 29 2016, 07:52 PM
ClayPerrine   Memmek2k, I want to apologize for these reprobate...   Dec 30 2016, 08:44 PM
steuspeed   :wttc: My door handle broke the day I bought mine ...   Dec 31 2016, 01:03 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:57 PM
