| Ncchany |
Jan 6 2017, 02:38 PM
Newbie ![]() Group: Members Posts: 36 Joined: 1-October 16 From: New york Member No.: 20,456 Region Association: None |
Hey guys i am going to try and remove the engine from my 914 today any advice? I am kinda scared to be honest. Is there any advice u guys can offer? I dont have a lift i am going to use a 3 ton floor jack and jackstands along with a furniture dolly. I think i am going to have trouble removing the cv joint.
| ntmatter |
Jan 6 2017, 10:50 PM
Newbie ![]() Group: Members Posts: 46 Joined: 10-May 11 From: Gig Harbor, WA Member No.: 13,049 Region Association: None |
Reading down through the comments, in terms of wiring that's considerably less complicated than hoses. Hoses come off altogether, wire harnesses are typically cut to size and hang right exactly where they need to go when the motor goes back in. Also, generally things are engineered so that if there are several harness connections in a single area, only one plug will fit in the right spot. Unlike a modern car, there's very little on these in the way of electronics so not much to fuss with.
Ncchany Going to remove engine today Jan 6 2017, 02:38 PM
bretth
Hey guys i am going to try and remove the engine ... Jan 6 2017, 02:59 PM
michael7810 There's a do it yourself article on the bird s... Jan 6 2017, 03:02 PM
mramber
There's a do it yourself article on the bird ... Jan 6 2017, 04:37 PM
ConeDodger
There's a do it yourself article on the bird ... Jan 6 2017, 07:55 PM
cuddyk Pretty straightforward if you follow the Bird chec... Jan 6 2017, 03:27 PM
Porschef You won't have trouble with the CV joints if y... Jan 6 2017, 03:30 PM
Garold Shaffer :agree: what with has been said so far. Read the ... Jan 6 2017, 04:10 PM
Ncchany I think the only thing that really confuses me is ... Jan 6 2017, 07:47 PM
ntmatter The articles above helped me to remove mine last y... Jan 6 2017, 10:19 PM
ntmatter One other thing - both my motor mount bolts were b... Jan 6 2017, 10:30 PM
Ncchany
Reading down through the comments, in terms of wi... Jan 6 2017, 11:46 PM
cuddyk No... that's Star drive. You'll need an M8... Jan 7 2017, 01:06 AM
wndsrfr
No... that's Star drive. You'll need an M... Jan 7 2017, 11:46 AM
Porschef Great point about cleaning the socket on the CV bo... Jan 7 2017, 08:31 AM
The Cabinetmaker I'll add: use a hammer and tap it in to insure... Jan 7 2017, 10:57 AM
cuddyk Since this question seems to come up a lot, I f fi... Jan 7 2017, 12:19 PM
SKL1 Good luck- it is not that hard. I've done i... Jan 7 2017, 01:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:18 PM |
