> Going to remove engine today, Engine removal
Ncchany
post Jan 6 2017, 02:38 PM
Hey guys i am going to try and remove the engine from my 914 today any advice? I am kinda scared to be honest. Is there any advice u guys can offer? I dont have a lift i am going to use a 3 ton floor jack and jackstands along with a furniture dolly. I think i am going to have trouble removing the cv joint.
iankarr
post Jan 7 2017, 01:06 AM
No... that's Star drive. You'll need an M8 triple square like this....
https://www.jbtoolsales.com/cta-tools-8512-...CFQxWDQodwpAE4Q
Assuming the PO hasn't switched the bolts to hex sockets like mine did...
Make sure the socket is super clean so the tool can fully seat before attempting to unscrew. Shooting some brake cleaner will do the trick, but wear eye protection.
wndsrfr
post Jan 7 2017, 11:46 AM
QUOTE(cuddyk @ Jan 6 2017, 11:06 PM) *
You can usually find the triple square bit at NAPA stores also--it may have a hex back end that you put a 13mm socket on to turn it. Frankly, I hate the triple square bolts--way too easy to strip. Check some of the member vendors here for hex head bolts that are drilled for safety wire--'way worth the investment, and you'll get new schnorr washers also....
As to the wiring & hoses, I use blue painter's tape and a marker to number them on both ends--easy peasy going back together....even if it's a year later!
Ncchany   Going to remove engine today   Jan 6 2017, 02:38 PM
bretth   Hey guys i am going to try and remove the engine ...   Jan 6 2017, 02:59 PM
michael7810   There's a do it yourself article on the bird s...   Jan 6 2017, 03:02 PM
mramber   There's a do it yourself article on the bird ...   Jan 6 2017, 04:37 PM
ConeDodger   There's a do it yourself article on the bird ...   Jan 6 2017, 07:55 PM
cuddyk   Pretty straightforward if you follow the Bird chec...   Jan 6 2017, 03:27 PM
Porschef   You won't have trouble with the CV joints if y...   Jan 6 2017, 03:30 PM
Garold Shaffer   :agree: what with has been said so far. Read the ...   Jan 6 2017, 04:10 PM
Ncchany   I think the only thing that really confuses me is ...   Jan 6 2017, 07:47 PM
ntmatter   The articles above helped me to remove mine last y...   Jan 6 2017, 10:19 PM
ntmatter   One other thing - both my motor mount bolts were b...   Jan 6 2017, 10:30 PM
ntmatter   Reading down through the comments, in terms of wir...   Jan 6 2017, 10:50 PM
Ncchany   Reading down through the comments, in terms of wi...   Jan 6 2017, 11:46 PM
cuddyk   No... that's Star drive. You'll need an M8...   Jan 7 2017, 01:06 AM
wndsrfr   No... that's Star drive. You'll need an M...   Jan 7 2017, 11:46 AM
Porschef   Great point about cleaning the socket on the CV bo...   Jan 7 2017, 08:31 AM
The Cabinetmaker   I'll add: use a hammer and tap it in to insure...   Jan 7 2017, 10:57 AM
cuddyk   Since this question seems to come up a lot, I f fi...   Jan 7 2017, 12:19 PM
SKL1   Good luck- it is not that hard. I've done i...   Jan 7 2017, 01:51 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:10 PM
