| tazz9924 |
Jan 8 2017, 02:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
So. I own a baja bug and a popular off road upgrade for it is a cutting/ turning brake. My question is why arnt these used in road racing as an alternative for left foot braking? this would direct braking force torwards the inside wheel(s) and may allow for faster and tighter cornering.
(Edit): I found that mclaren used a system similar to this in 97-98 in F1 and is a system currently employed in modern mclaren road cars. Instead of a grab handle it was a switchable 3rd pedal to the left of the brake pedal (they dont have clutches) Conservative estimates say it was good for .3 seconds a lap! It was banned from F1 on the grounds that it was a 4 wheel steering system. More info can be found here: http://www.motorsportmagazine.com/archive/...e-steer-mclaren ![]() Attached image(s)
| Cracker |
Jan 9 2017, 08:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
To piggy back on that excellent explanation - in the most basic form, of course. You rarely see road race cars excessively "loosing lateral traction" while cornering; as in drifting. Not only is "smooth generally the fastest way around a course" SO is maintaining the cars speed through a corner. In fact, this is the skill that separates the men with big balls from those with little ones. Period. Anyone can blast down the straights...stopping properly is a different matter though!
Ironically, the old racing cliche that indirectly ties into this discussion is, "Brakes, who needs those? They only slow you down...) is at play here. While trail braking helps rotate a car more quickly into a corner; it is power down from apex-out; unlike the drifting technique used in off-road cars. Each car that is properly set up will have a "point" in which is the sweet spot during its rotation - the term that is used in racing is "setting the rear". It is hard to describe but once you have "felt it" - you know how far you can push the car (any further and you will do a loopy-lew)! BTW: Left foot braking is an acquired skill..I learned to LFB in my Prototype - it is as natural now as anything else I have ever done. Tony |
| 6freak |
Jan 9 2017, 09:26 AM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
To piggy back on that excellent explanation - in the most basic form, of course. You rarely see road race cars excessively "loosing lateral traction" while cornering; as in drifting. Not only is "smooth generally the fastest way around a course" SO is maintaining the cars speed through a corner. In fact, this is the skill that separates the men with big balls from those with little ones. Period. Anyone can blast down the straights...stopping properly is a different matter though! Ironically, the old racing cliche that indirectly ties into this discussion is, "Brakes, who needs those? They only slow you down...) is at play here. While trail braking helps rotate a car more quickly into a corner; it is power down from apex-out; unlike the drifting technique used in off-road cars. Each car that is properly set up will have a "point" in which is the sweet spot during its rotation - the term that is used in racing is "setting the rear". It is hard to describe but once you have "felt it" - you know how far you can push the car (any further and you will do a loopy-lew)! BTW: Left foot braking is an acquired skill..I learned to LFB in my Prototype - it is as natural now as anything else I have ever done. Tony last two post are good IMO..yep anyone can drive fast in a strait line like ive always said.. ..setting the rear or as i say, you feel it take a set, all the weight has shifted to the outside tires and the car is stuck to the road,but your right on the edge as mentioned the feeling comes from the thing your sitting on (IMG:style_emoticons/default/bootyshake.gif) the term trail braking is brakes and gas at the same time IIRC...trying to get the car to take a good set or tranfer weight while still maintaining momentum into the corner so you can apply max power at apex coming out....it doesnt mean use back brakes only especially one side or the other....Mr Tazz come out for some AX this season and hone your skills with the rest of use PNW region folks but leave your"off road" turning brakes at home (IMG:style_emoticons/default/laugh.gif) MikeC |
| Cracker |
Jan 9 2017, 09:34 AM
Mike - It "could" include the throttle but the actual technique is generally off-throttle. When a vehicles brakes are being applied from a "turn-in point" up to or through the apex (it makes little sense to continue past apex as mentioned earlier because you want to accelerate at that point). Again, it is generally performed off-throttle...
Also, the OP mentioned AX...a completely different game than the road course environment I am referring to. Tony the term trail braking is brakes and gas at the same time IIRC... MikeC |
tazz9924 Racing question i have never heard of before Jan 8 2017, 02:51 PM
jmill They are already on many drift cars. However, dri... Jan 8 2017, 03:01 PM
tazz9924
They are already on many drift cars. However, dr... Jan 8 2017, 03:09 PM
stanthedog Aren't they illegal for road use. I'd thin... Jan 8 2017, 03:38 PM
Mueller In real racing you want both hands on the wheel, w... Jan 8 2017, 03:38 PM
Cracker ...it is called "trail-braking" in road ... Jan 8 2017, 03:40 PM
Mueller
So. I own a baja bug and a popular off road upgra... Jan 8 2017, 03:42 PM
Mark Henry For turning tight corners at slow speed.
My Fiat ... Jan 8 2017, 04:53 PM
jmill
They are already on many drift cars. However, d... Jan 8 2017, 05:00 PM
6freak [quote name='tazz9924' date='Jan 8 201... Jan 8 2017, 06:55 PM
sixaddict Rally cars use them on really tight turns ....in r... Jan 8 2017, 07:14 PM
tazz9924
Rally cars use them on really tight turns ....in ... Jan 8 2017, 11:08 PM
jmitro :agree:
not to mention it would be against the r... Jan 8 2017, 07:32 PM
tazz9924
:agree:
not to mention it would be against the ... Jan 8 2017, 11:10 PM
raynekat Easy answer....these work only on the rear wheels ... Jan 9 2017, 12:49 AM
stugray The only use this would have on a road racing car ... Jan 9 2017, 07:58 AM
ThePaintedMan This is the only road racing example that I know o... Jan 9 2017, 08:16 AM
GregAmy The (somewhat) quick answer: rear wheel turning br... Jan 9 2017, 08:16 AM
tazz9924
Mike - It "could" include the throttle ... Jan 9 2017, 11:01 AM
Mueller
[quote name='Cracker' post='2442225' date='Jan 9 ... Jan 9 2017, 11:50 AM
tazz9924
Hey it was just something i thought of searching ... Jan 9 2017, 10:58 AM
ConeDodger The spin would be epic at road race speeds... :bl... Jan 9 2017, 08:46 AM
Cracker
The spin would be epic at road race speeds... :b... Jan 9 2017, 08:59 AM
Cracker Tazz - I didn't mean to imply the idea wasn... Jan 9 2017, 12:03 PM
stugray There is some confusion and incorrect explanation ... Jan 9 2017, 01:48 PM
Cracker I often trail brake very late, depending on many f... Jan 9 2017, 01:59 PM
brant fun....
we all have different interpretations
Tr... Jan 9 2017, 02:32 PM
Dave_Darling
subsequently the trail braking transfers some of ... Jan 9 2017, 11:12 PM
6freak
Your rear tires are also below the CG, unless t... Jan 10 2017, 09:35 AM
tazz9924
Your rear tires are also below the CG, unless ... Jan 10 2017, 11:56 AM
6freak as i thought i just couldnt explain it like you ... Jan 9 2017, 04:22 PM
tazz9924
as i thought i just couldnt explain it like you... Jan 9 2017, 08:11 PM
tazz9924 I was right! more info in first post and you c... Feb 8 2017, 12:51 PM
6freak
I was right! more info in first post and you ... Feb 8 2017, 03:33 PM
ThePaintedMan
I was right! more info in first post and you ... Feb 8 2017, 03:58 PM
tazz9924
[quote name='tazz9924' post='2452685' date='Feb 8... Feb 8 2017, 08:40 PM
rhodyguy Where are you driving that you might want an EXTRA... Feb 8 2017, 02:56 PM
JmuRiz Engineering Explained talked a bit about this toda... Feb 8 2017, 03:28 PM
stugray
Engineering Explained talked a bit about this tod... Feb 8 2017, 05:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:29 PM |
