> Racing question i have never heard of before, It actually exists and is banned from F1!
tazz9924
post Jan 8 2017, 02:51 PM
So. I own a baja bug and a popular off road upgrade for it is a cutting/ turning brake. My question is why arnt these used in road racing as an alternative for left foot braking? this would direct braking force torwards the inside wheel(s) and may allow for faster and tighter cornering.
(Edit): I found that mclaren used a system similar to this in 97-98 in F1 and is a system currently employed in modern mclaren road cars. Instead of a grab handle it was a switchable 3rd pedal to the left of the brake pedal (they dont have clutches) Conservative estimates say it was good for .3 seconds a lap! It was banned from F1 on the grounds that it was a 4 wheel steering system. More info can be found here: http://www.motorsportmagazine.com/archive/...e-steer-mclarenAttached Image
Cracker
post Jan 9 2017, 08:31 AM
To piggy back on that excellent explanation - in the most basic form, of course. You rarely see road race cars excessively "loosing lateral traction" while cornering; as in drifting. Not only is "smooth generally the fastest way around a course" SO is maintaining the cars speed through a corner. In fact, this is the skill that separates the men with big balls from those with little ones. Period. Anyone can blast down the straights...stopping properly is a different matter though!
Ironically, the old racing cliche that indirectly ties into this discussion is, "Brakes, who needs those? They only slow you down...) is at play here. While trail braking helps rotate a car more quickly into a corner; it is power down from apex-out; unlike the drifting technique used in off-road cars.
Each car that is properly set up will have a "point" in which is the sweet spot during its rotation - the term that is used in racing is "setting the rear". It is hard to describe but once you have "felt it" - you know how far you can push the car (any further and you will do a loopy-lew)!
BTW: Left foot braking is an acquired skill..I learned to LFB in my Prototype - it is as natural now as anything else I have ever done.
Tony
6freak
post Jan 9 2017, 09:26 AM
MR.C
QUOTE(Cracker @ Jan 9 2017, 06:31 AM) *
Tony
last two post are good IMO..yep anyone can drive fast in a strait line like ive always said.. ..setting the rear or as i say, you feel it take a set, all the weight has shifted to the outside tires and the car is stuck to the road,but your right on the edge as mentioned
the feeling comes from the thing your sitting on (IMG:style_emoticons/default/bootyshake.gif)
the term trail braking is brakes and gas at the same time IIRC...trying to get the car to take a good set or tranfer weight while still maintaining momentum into the corner so you can apply max power at apex coming out....it doesnt mean use back brakes only especially one side or the other....Mr Tazz come out for some AX this season and hone your skills with the rest of use PNW region folks but leave your"off road" turning brakes at home (IMG:style_emoticons/default/laugh.gif)
MikeC
Cracker
post Jan 9 2017, 09:34 AM
Mike - It "could" include the throttle but the actual technique is generally off-throttle. When a vehicles brakes are being applied from a "turn-in point" up to or through the apex (it makes little sense to continue past apex as mentioned earlier because you want to accelerate at that point). Again, it is generally performed off-throttle...
Also, the OP mentioned AX...a completely different game than the road course environment I am referring to.
Tony
QUOTE(6freak @ Jan 9 2017, 10:26 AM) *
MikeC
tazz9924
post Jan 9 2017, 11:01 AM
QUOTE(Cracker @ Jan 9 2017, 07:34 AM) *
Tony
MikeC
Autox Its just a place i could test, realistically i don't have money to vigorously test on a road course.
tazz9924   Racing question i have never heard of before   Jan 8 2017, 02:51 PM
jmill   They are already on many drift cars. However, dri...   Jan 8 2017, 03:01 PM
tazz9924   They are already on many drift cars. However, dr...   Jan 8 2017, 03:09 PM
stanthedog   Aren't they illegal for road use. I'd thin...   Jan 8 2017, 03:38 PM
Mueller   In real racing you want both hands on the wheel, w...   Jan 8 2017, 03:38 PM
Cracker   ...it is called "trail-braking" in road ...   Jan 8 2017, 03:40 PM
Mueller   So. I own a baja bug and a popular off road upgra...   Jan 8 2017, 03:42 PM
Mark Henry   For turning tight corners at slow speed. My Fiat ...   Jan 8 2017, 04:53 PM
jmill   They are already on many drift cars. However, d...   Jan 8 2017, 05:00 PM
6freak   [quote name='tazz9924' date='Jan 8 201...   Jan 8 2017, 06:55 PM
sixaddict   Rally cars use them on really tight turns ....in r...   Jan 8 2017, 07:14 PM
tazz9924   Rally cars use them on really tight turns ....in ...   Jan 8 2017, 11:08 PM
jmitro   :agree: not to mention it would be against the r...   Jan 8 2017, 07:32 PM
tazz9924   :agree: not to mention it would be against the ...   Jan 8 2017, 11:10 PM
raynekat   Easy answer....these work only on the rear wheels ...   Jan 9 2017, 12:49 AM
stugray   The only use this would have on a road racing car ...   Jan 9 2017, 07:58 AM
ThePaintedMan   This is the only road racing example that I know o...   Jan 9 2017, 08:16 AM
GregAmy   The (somewhat) quick answer: rear wheel turning br...   Jan 9 2017, 08:16 AM
Cracker   To piggy back on that excellent explanation - in t...   Jan 9 2017, 08:31 AM
6freak   To piggy back on that excellent explanation - in ...   Jan 9 2017, 09:26 AM
Cracker   Mike - It "could" include the throttle b...   Jan 9 2017, 09:34 AM
tazz9924   Mike - It "could" include the throttle ...   Jan 9 2017, 11:01 AM
Mueller   [quote name='Cracker' post='2442225' date='Jan 9 ...   Jan 9 2017, 11:50 AM
tazz9924   Hey it was just something i thought of searching ...   Jan 9 2017, 10:58 AM
ConeDodger   The spin would be epic at road race speeds... :bl...   Jan 9 2017, 08:46 AM
Cracker   The spin would be epic at road race speeds... :b...   Jan 9 2017, 08:59 AM
Cracker   Tazz - I didn't mean to imply the idea wasn...   Jan 9 2017, 12:03 PM
stugray   There is some confusion and incorrect explanation ...   Jan 9 2017, 01:48 PM
Cracker   I often trail brake very late, depending on many f...   Jan 9 2017, 01:59 PM
brant   fun.... we all have different interpretations Tr...   Jan 9 2017, 02:32 PM
Dave_Darling   subsequently the trail braking transfers some of ...   Jan 9 2017, 11:12 PM
6freak   Your rear tires are also below the CG, unless t...   Jan 10 2017, 09:35 AM
tazz9924   Your rear tires are also below the CG, unless ...   Jan 10 2017, 11:56 AM
6freak   as i thought i just couldnt explain it like you ...   Jan 9 2017, 04:22 PM
tazz9924   as i thought i just couldnt explain it like you...   Jan 9 2017, 08:11 PM
tazz9924   I was right! more info in first post and you c...   Feb 8 2017, 12:51 PM
6freak   I was right! more info in first post and you ...   Feb 8 2017, 03:33 PM
ThePaintedMan   I was right! more info in first post and you ...   Feb 8 2017, 03:58 PM
tazz9924   [quote name='tazz9924' post='2452685' date='Feb 8...   Feb 8 2017, 08:40 PM
rhodyguy   Where are you driving that you might want an EXTRA...   Feb 8 2017, 02:56 PM
JmuRiz   Engineering Explained talked a bit about this toda...   Feb 8 2017, 03:28 PM
stugray   Engineering Explained talked a bit about this tod...   Feb 8 2017, 05:19 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 PM
