| McMark |
Nov 25 2016, 11:52 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
About a year ago I struck a deal with Pete at Restoration Design to start reproducing the 914-6 dash piece. I gave him a discount on a fuel injection system in trade for the die development costs. He finished these up awhile ago, and they're now available on his web site. But it wasn't until now that I had time to install one. It's a pretty easy process that I'll detail here.
Here's the repalcement piece from RD. I intended the design to be cut apart and not installed as one piece. The idea is that you can mark the lock section and cut it out. And then what you're left with is the new piece and a template to mark the location where the new piece goes. The switch 'bump' and the little notch at the bottom of the dash are the alignment markers. It's not idiot proof though, so measure twice and cut once. Marking where I want the cuts. ![]() Precision cutoff wheel work. (IMG:style_emoticons/default/sunglasses.gif) ![]() Template in place to mark dash for cutting. More precision surgery. (IMG:style_emoticons/default/av-943.gif) Replacement piece fits in the hole. I TIG welded it, but MIG works fine. Go slow, take brakes. Heat is the enemy. ![]() Grind and smooth to a no-filler needed finish. ![]() All in all, it took me almost exactly 2 hours to install the piece. It's lined up perfectly with the other holes and it's ready for install. I can do these for $200, send your dash to me and I'll convert it. This one isn't spoken for, but I'm saving first right of refusal for Rob (ConeDodger) since last I heard he wanted a left ignition. (IMG:style_emoticons/default/bye1.gif) |
| McMark |
Jan 16 2017, 08:09 AM
The 914-6 steel column (steel tube portion) is about 8-9/16"
The four cylinder column (steel tube portion) is about 6" long. |
McMark Left Side Ignition Nov 25 2016, 11:52 AM
Mueller Neat! Nov 25 2016, 11:59 AM
jim_hoyland Which bezel will fit in the depression ?
And you ... Nov 25 2016, 02:15 PM
McMark The original 914-6 bezel isn't available. But... Nov 25 2016, 02:22 PM
Mark Henry I had this part in my hand...maybe even that actua... Nov 25 2016, 02:31 PM
mb911 I plan to do this at some point.. I need so many o... Nov 25 2016, 02:57 PM
I plan to do this at some point.. I need so many ... Nov 25 2016, 04:17 PM
mb911
I plan to do this at some point.. I need so many... Nov 25 2016, 05:02 PM
Krieger Nice work Mark! Great planning for an easy in... Nov 25 2016, 04:47 PM
jim_hoyland Mark,. Would you post a pic with the ignition inse... Nov 25 2016, 05:16 PM
McMark Sunday will be the soonest I can. But no problem. Nov 25 2016, 05:41 PM
ConeDodger I want it! >:D Nov 25 2016, 09:29 PM
jim_hoyland
I want it! >:D
Are going to do the full... Nov 26 2016, 06:02 PM
ConeDodger
I want it! >:D
Are going to do the ful... Nov 26 2016, 07:01 PM
jim_hoyland
I want it! >:D
Harpo Very nicely done Mark Nov 26 2016, 07:10 AM
sixaddict Mark:
Is there any difference in the dash (70/71) ... Nov 26 2016, 08:06 AM
Mark:
Is there any difference in the dash (70/71)... Nov 26 2016, 09:44 AM
sixaddict
Mark:
Is there any difference in the dash (70/71... Nov 26 2016, 10:38 AM
McMark
[quote name='mepstein' post='2427500' date='Nov 2... Nov 26 2016, 02:15 PM
McMark
Mark:
Is there any difference in the dash (70/71)... Nov 26 2016, 02:12 PM
396 Congrats with getting this part recreated. I gues... Nov 26 2016, 08:51 AM
mb911
Congrats with getting this part recreated. I gue... Nov 26 2016, 09:01 AM
Congrats with getting this part recreated. I gu... Nov 26 2016, 09:54 AM
Mark Henry Could someone make a list of the parts needed to d... Nov 26 2016, 09:31 AM
Larmo63 I found this older 911 switch and thought it might... Nov 26 2016, 12:06 PM
jim_hoyland
I found this older 911 switch and thought it migh... Nov 26 2016, 06:04 PM
tweet
I found this older 911 switch and thought it mig... Jan 9 2017, 09:06 PM
McMark Dash escutcheon picture. Apparently AutoAtlanta ... Nov 26 2016, 02:20 PM
396
Dash escutcheon picture. Apparently AutoAtlanta... Nov 26 2016, 07:47 PM
McMark
Quick question, how were you able to locate this ... Nov 27 2016, 03:33 PM
396
Quick question, how were you able to locate this... Nov 27 2016, 07:22 PM
Larmo63 It has a Porsche key in it. I'll use that. Thi... Nov 26 2016, 06:19 PM
jim_hoyland
It has a Porsche key in it. I'll use that. Th... Nov 26 2016, 06:25 PM
McMark Here ya' go... Nov 27 2016, 03:31 PM
Steve Curious Mark... what if we do not want the expens... Nov 27 2016, 04:36 PM
jim_hoyland
Curious Mark... what if we do not want the expen... Nov 27 2016, 04:53 PM
jim_hoyland Found it; only $29.95......yikes :blink: Nov 27 2016, 08:36 PM
rick 918-S Mark, there is a washer that goes on before the sh... Nov 28 2016, 05:31 AM
McMark
Mark, there is a washer that goes on before the s... Nov 28 2016, 09:11 AM
Harpo
Mark, there is a washer that goes on before the ... Jan 16 2017, 09:34 AM
sixnotfour its the same as the same year 911, but the PN is s... Nov 28 2016, 11:00 AM
jim_hoyland
its the same as the same year 911, but the PN is ... Nov 28 2016, 11:32 AM
tweet
its the same as the same year 911, but the PN is ... Jan 9 2017, 09:20 PM
McMark Yup, in the following order...
Ignition Switch ... Nov 28 2016, 01:19 PM
sixnotfour Nice job McMark, :beer2:
uneducated viewer , ya ... Dec 1 2016, 11:02 AM
Harpo What year 911 column do I need for this conversion... Dec 3 2016, 08:46 PM
McMark Only early cars and real 914-6 steering column wil... Dec 4 2016, 11:01 AM
sixnotfour 911 columns 69-73 Dec 4 2016, 01:25 PM
Harpo
911 columns 69-73
Just in case anyone was wonde... Jan 16 2017, 06:25 AM
jim_hoyland
[quote name='sixnotfour' post='2430287' date='Dec... Jan 16 2017, 07:35 AM
Mark Henry
[quote name='sixnotfour' post='2430287' date='Dec... Jan 17 2017, 09:54 PM
mb911
[quote name='sixnotfour' post='2430287' date='De... Jan 18 2017, 06:16 AM
Steve What if you don't care about the column switch... Dec 4 2016, 02:04 PM
jim_hoyland
What if you don't care about the column switc... Dec 4 2016, 02:14 PM
jim_hoyland
What if you don't care about the column switc... Dec 5 2016, 05:19 PM
tweet
What if you don't care about the column swit... Jan 9 2017, 09:38 PM
McMark Yup, absolutely. Dec 5 2016, 08:05 AM
SixerJ Mark 1stly apologies for the hijack. I was thinkin... Dec 20 2016, 05:34 PM
rhodyguy Is there a desired plastic 'cup' on the ba... Dec 20 2016, 07:44 PM
Is there a desired plastic 'cup' on the b... Dec 20 2016, 08:18 PM
SixerJ More pictures
Wiper stalk switches, from Right to... Dec 21 2016, 06:38 AM
SixerJ More
I have figured out that there is indeed a di... Dec 21 2016, 06:48 AM
McMark This is turning into a great overall how-to thread... Dec 21 2016, 06:58 AM
Mark Henry I'm seeing two ways, a no lock with what looks... Dec 21 2016, 07:53 AM
SixerJ
I'm seeing two ways, a no lock with what look... Dec 21 2016, 08:37 AM
Harpo Here is my diy 914-6 column
Dec 21 2016, 09:22 PM
gereed75 Mark, do you have any of the replacement bearing ... Dec 22 2016, 07:32 AM
McMark Gotta look if I still have my shim information or ... Dec 22 2016, 01:08 PM
gereed75
Gotta look if I still have my shim information or... Dec 22 2016, 01:18 PM
Gotta look if I still have my shim information or... Dec 22 2016, 01:19 PM
Harpo Mark I would be interested in your bearing fix as ... Jan 10 2017, 07:33 PM
Niklas Do we have Porsche part no for all the parts neede... Dec 22 2016, 01:33 PM
BuddyV "Escutcheon"..... :)
Only other time ... Dec 22 2016, 09:17 PM
Harpo I like trim ring, I can actually spell that Dec 23 2016, 05:21 PM
Larmo63 BTW, I have two of theses ignition switches. I... Jan 10 2017, 12:42 AM
McMark I kinda thought so. Have one sitting here for you... Jan 11 2017, 06:41 AM
Harpo Certainly not perfect but it will work in the shor... Jan 16 2017, 01:10 PM
mb911 How come the -6 dash as such a deep recess versus ... Jan 16 2017, 04:10 PM
Harpo I believe it has to do with the angle of the dash. Jan 16 2017, 04:31 PM
mb911
I believe it has to do with the angle of the dash... Jan 16 2017, 05:36 PM
Mark Henry That's why I'm asking if you can just fab ... Jan 18 2017, 07:39 AM
mb911
That's why I'm asking if you can just fab... Jan 18 2017, 03:03 PM
tweet Hello All,
We are trying to date when certain chan... Jan 20 2017, 11:55 AM
SixerJ
Hello All,
We are trying to date when certain cha... Jan 21 2017, 01:44 AM
Harpo I'm sure that it can be converted especially s... Jan 20 2017, 07:34 PM
Mark Henry Just got a deal on a 69-73 column from my buddy wh... Jan 21 2017, 06:54 PM
mb911
Just got a deal on a 69-73 column from my buddy w... Jan 22 2017, 07:29 AM
Mark Henry
Only thing is the switch doesn't have keys, ... Jan 31 2017, 04:03 PM
Mark Henry Thanks Ben. :wavebye: Jan 22 2017, 08:15 AM
mb911
Np.. If you need pictur... Jan 22 2017, 09:05 AM
Mark Henry Here's my collection so far :
I just got the i... Jan 28 2017, 08:33 AM
mb911 If you flip the switch with the key portion facing... Jan 28 2017, 08:54 AM
Mark Henry
If you flip the switch with the key portion facin... Jan 28 2017, 08:59 AM
mb911
If you flip the switch with the key portion faci... Jan 28 2017, 09:08 AM
Harpo Mark, mine were the same way. Mine came right out... Jan 28 2017, 12:09 PM
Mark Henry
Mark, mine were the same way. Mine came right ou... Jan 28 2017, 11:38 PM
Larmo63 I have a couple of early ignition switches for sal... Jan 28 2017, 02:17 PM
Harpo It appears that the 914 & 911 column are very ... Feb 19 2017, 10:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2025 - 05:55 AM |
