Rear Wheel Bearing Difference, Comparison that may have caused my failures |
914Sixer |
Jan 15 2017, 03:50 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
For months now I have maintained there is a big difference in the quality of the new rear bearings verses the original ones. Today I had time to compare an original FAG (Germany)and a new SKF (Italy) bearing shells. MY conclusion is what I suspected, the new ones are NOT the same. I took pictures and measurements to document what I saw. I hope the pictures let you see the difference. Guess which one is the original German one!
Attached image(s) |
IronHillRestorations |
Jan 15 2017, 07:26 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I wonder what the age cut off for these are. I've got a stash of several sets.
6freak |
Jan 18 2017, 09:04 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I wonder what the age cut off for these are. I've got a stash of several sets. bearings do have a shelf life beleave it or not and your supposed to turn them over every year... because the earth has a constant vibration (IMG:style_emoticons/default/wacko.gif) and the ball train has a harmonic point (vibration) at a set speed which cause`s premature failure ,change the amount of balls and the harmonics change and mass dampens vibration....... (IMG:style_emoticons/default/smile.gif) |
914_teener |
Jan 18 2017, 01:10 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I wonder what the age cut off for these are. I've got a stash of several sets. bearings do have a shelf life beleave it or not and your supposed to turn them over every year... because the earth has a constant vibration (IMG:style_emoticons/default/wacko.gif) and the ball train has a harmonic point (vibration) at a set speed which cause`s premature failure ,change the amount of balls and the harmonics change and mass dampens vibration....... (IMG:style_emoticons/default/smile.gif) At that point....your swing arm droops. I think you.ve lost your bearing. |
6freak |
Jan 18 2017, 04:24 PM
I wonder what the age cut off for these are. I've got a stash of several sets. bearings do have a shelf life beleave it or not and your supposed to turn them over every year... because the earth has a constant vibration (IMG:style_emoticons/default/wacko.gif) and the ball train has a harmonic point (vibration) at a set speed which cause`s premature failure ,change the amount of balls and the harmonics change and mass dampens vibration....... (IMG:style_emoticons/default/smile.gif) At that point....your swing arm droops. I think you.ve lost your bearing. look it up then get back to me (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 05:45 AM |
