1970 porsche 914 wiring questions |
jfab |
Jan 22 2017, 09:03 PM
Newbie Group: Members Posts: 16 Joined: 20-January 17 From: mass Member No.: 20,767 Region Association: North East States |
long story short, the PO cannot wire cars so assume the worst
first is first, im assuming this blue wire is for the horn at the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.1.jpg) i also found this blue wire attached to the relay board under the kneeboard. guessing this goes to the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.2.jpg) it is attached to the relay board here, same spade connector as the only non corroded terminal (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.3.jpg) this disconnected wire goes to ground i assume? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.4.jpg) and lastly, what is supposed to go to the pole #6 on this connector? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140580.5.jpg) |
JeffBowlsby |
Jan 22 2017, 10:02 PM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) |
larryM |
Jan 22 2017, 10:43 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Jeff: thanks for that hand drawn diagram - might be the clue i needed i've been working on my wiring to rewire/mod a few things & fix the euro-park feature which had been reversed ever since the car came to USA, and found a disconnected gray wire near the new JWest panel - it has an oem female spade on it & looks like it ought to belong to the fuse panel - but i could not find it in my wiring chart - has no continuity to any other point that i could find so far - and does not have 12v on it anytime (it's NOT the wire that feeds the trunk & license lights - i have a different gray one for that - and fixed it after 30 yrs) i also find another cut-off gray wire & am looking for what that belongs to - same no continuity, no 12v . |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:57 AM |
