andrewvolsen |
Newbie ![]() Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California ![]() |
My '74 1.8 L-Jet 914 has developed a light load hesitation/stumble. It is the most pronounced when cruising on flat ground with light accelerator application, maybe 10% opening of the butterfly valve. The stumble is not noticeable when accelerating.
The car has: - New vacuum lines - New plugs, wires, cap, rotor, and coil (still running points) - Cleaned throttle body and checked operation of TPS - New accelerator pedal and throttle cable - Rebuilt MAF - Recent valve adjustment Does anyone have any suggestions for how to proceed with diagnosing the cause of my light load stumble (IMG:style_emoticons/default/confused24.gif) |
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
By chance does it happen right around 2k rpm?
If so you may need a slight adjustment to the TPS. If the ECU thinks the throttle is closed above 2k rpm, it kills the fuel to the engine. When/if the engine hits 2k rpm, it adds fuel again. When the TPS is misadjusted, you can be trying to do a part throttle cruise, but the ECU cuts in and out with the fuel. If it is happening above 2k rpm, you may have a lean condition requiring a slight tweak of the MPS. |
Lo-Fi Version | Time is now: 16th June 2024 - 05:18 PM |
