Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
Cracker |
Jan 25 2017, 05:51 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
...not a "racer" but I do have a hot-rod with more mass (mike) - I obviously do no run a "T" in my car. Also, the hydraulic (plunger) style proportioning valve does not provide enough adjustment for my application. My "large" changes are made with the balance bar - the plunger style valve mounted on the console is for the fine-tuned, on track adjustments. The only "914" I have ever spun (on a track) was a stock-ish car, with all OE installed.
T |
Lo-Fi Version | Time is now: 11th June 2024 - 01:54 AM |
