| kupcar |
Jan 24 2017, 05:46 PM
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
Hi Guys, It's time to do some routine off season maintenance on the 914. The car has a 2.2s spec motor. My question is, how do -6 owners adjust the ignition timing prior to a valve adjustment? It looks damn near impossible to get a timing light reading. I know cutting into the firewall is an option for ease of access but I'm not willing to get the cutoff wheel out yet. Does everyone drop the motor and tune at a shop that has a running motor stand? I'd just like to double check the ignition before setting the valves. Thanks in advance.
| '73-914kid |
Jan 24 2017, 09:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I exclusively use the back side method as described on Pelican. Much much easier on a 914, where you can physically look down on the cam lobe. It also eliminates the need for a "feel" when using the standard 0.006" feeler gauge that always seems to get bent and folded.
1. Jack up one side of the car, using jack stands... put the car in a forward gear, with the parking brake off. I recommend chalking the wheel on the ground. I also pull out the spark plugs. When I do valves, I usually swap out spark plugs as the MSD box and hot coil are kinda tough on spark plugs, and they're cheap and easy. 2. Remove both the exhaust and intake cam covers. 3. Start the back side method described on Pelican. You rotate the tire FORWARD while looking down from the top and watch the exhaust cam lobe rotate so the top of the lobe is facing 180 degrees from the rocker arm. ( no lift) go underneath and adjust the valve using go, no-go feeler gauges. 4. Go underneath the car and watch the intake cam lobe rotate 180 degrees away from the rocker arm. Measure and adjust. Wash-rinse-repeat for all valves on one side. then go over and do the same for the other side. I can usually pull off a valve adjustment in about 90 minutes start to finish using this method. Oh, and you can replace the upper row of studs on the exhaust cam cover with socket head cap screws.. this allows an unmodified 930 cam cover to be R&R'd with the engine in the car..... |
| mskala |
Jan 25 2017, 08:32 AM
R ![]() ![]() ![]() Group: Members Posts: 1,942 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
... Oh, and you can replace the upper row of studs on the exhaust cam cover with socket head cap screws.. this allows an unmodified 930 cam cover to be R&R'd with the engine in the car..... If you do this you won't have the nyloc helping to avoid fasteners loosening. I don't think there is a lockwasher that would work at the low torque used to seat but not crush the gasket. |
kupcar 914-6 Valve Adjustment Advice Jan 24 2017, 05:46 PM
jcd914 Smoke and Mirrors!
Well actually you don... Jan 24 2017, 05:50 PM
toolguy That is why real six's have the timing marks o... Jan 24 2017, 05:59 PM
mountainroads
That is why real six's have the timing marks ... Jan 25 2017, 09:32 AM
6freak
That is why real six's have the timing marks ... Jan 25 2017, 12:38 PM
fixer34 Your 'fun' has only begun. Wait until you ... Jan 24 2017, 06:42 PM
kupcar I actually thought about the mirror. Then I envisi... Jan 24 2017, 07:07 PM
fixer34
I actually thought about the mirror. Then I envis... Jan 26 2017, 05:19 PM
GeorgeRud You could always put paint marks on TDC and at the... Jan 24 2017, 07:37 PM
mskala If you really don't have any timing marks on t... Jan 24 2017, 08:06 PM
kupcar George, Thanks for the picture. I didn't even ... Jan 24 2017, 08:32 PM
maxwelj
Mark, I do have access to a lift. I'm going ... Jan 25 2017, 11:32 AM
porschetub never seen the point in these exhaust valve covers... Jan 24 2017, 08:41 PM
'73-914kid
... Oh, and you can replace the upper row of stu... Jan 25 2017, 08:56 AM
6freak [quote
Just use good judgement when tightening do... Jan 25 2017, 12:52 PM
Peashooter That's a great idea on replacing the top row o... Jan 25 2017, 08:21 AM
kupcar Great tips! I can't wait to dive into this... Jan 25 2017, 09:07 AM
rudedude Also the 6 cylinder valve spec is 0.01mm or .004... Jan 25 2017, 12:27 PM
Perry Kiehl Taking off the exhaust adds time and materials, bu... Jan 27 2017, 08:11 AM
db9146 Ethan,
Question regarding your suggestion to repl... Feb 1 2017, 09:29 PM
'73-914kid That's a great question. I actually don't ... Feb 1 2017, 10:08 PM
db9146 That would be fastastic!!!!
I rea... Feb 1 2017, 10:46 PM
forrestkhaag So if you want to "see" your pulley and ... Feb 1 2017, 10:57 PM
forrestkhaag I am taking PK's advice on milling depth of 5/... Feb 22 2017, 03:59 PM
Mark Henry There's a cool tool made by a pelican member t... Feb 22 2017, 05:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:18 AM |
