> fuel gauge sender, Bench testing
80cap
post Dec 5 2016, 01:46 PM
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian
Dave_Darling
post Jan 26 2017, 10:50 PM
914 Idiot
One of the three pins is ground, one is the signal for the light, and one is the sender for the gauge. See my earlier post about what sorts of readings you would expect from the latter to to the ground pin.
--DD
80cap   fuel gauge sender   Dec 5 2016, 01:46 PM
Dave_Darling   There should be three (possibly four) electrical c...   Dec 5 2016, 02:18 PM
80cap   Thanks Dave! Well like most things so far on m...   Dec 5 2016, 03:07 PM
914Bryan   Does anyone have pictures of this?   Dec 6 2016, 10:03 AM
jim_hoyland   :agree: Just went through this. The inside of the...   Dec 6 2016, 09:49 PM
Hans Jan   Just ran out of gas this evening. The reserve ligh...   Jan 25 2017, 09:59 PM
Dave_Darling   The warning light contacts are on the same float a...   Jan 25 2017, 10:29 PM
Hans Jan   The warning light contacts are on the same float ...   Jan 25 2017, 10:52 PM
bdstone914   The warning light contacts are on the same float...   Jan 26 2017, 09:42 AM
seatosummit   [quote name='Hans Jan' post='2448102' date='Jan 2...   Jul 20 2021, 10:55 PM
Dave_Darling   I will start looking for a new/used gauge. I su...   Jan 26 2017, 02:23 PM
fixer34   The warning light contacts are on the same float ...   Feb 12 2017, 02:14 PM
Hans Jan   Have not yet figured out how to read the resistanc...   Jan 26 2017, 06:51 PM
Hans Jan   See pic   Jan 26 2017, 06:51 PM
Dave_Darling   One of the three pins is ground, one is the signal...   Jan 26 2017, 10:50 PM
Hans Jan   After removing I find the following readings: Upsi...   Jan 27 2017, 03:10 PM
Dave_Darling   We had similar trouble when we bought the wife...   Feb 12 2017, 09:15 PM
914Sixer   Take the sending unit and let it soak in a some la...   Feb 12 2017, 09:57 PM
forrestkhaag   For what it is worth, I had to open my sender tube...   Feb 13 2017, 11:52 AM
Costa05   For what it is worth, I had to open my sender tub...   Nov 30 2020, 11:46 PM
Red76   The real thin wires on the outside edges of the fl...   Nov 3 2017, 02:11 PM
neilbardsley   I'm having a problem with my fuel sender/gauge...   Apr 13 2021, 01:39 PM
Retroracer   So that would point to either wiring or gauge bein...   Apr 13 2021, 02:25 PM
neilbardsley   So that would point to either wiring or gauge bei...   Apr 14 2021, 12:50 AM
Cairo94507   I just replaced my fuel sender. It was sticking a...   Apr 14 2021, 07:17 AM
neilbardsley   Ok. It's not the wiring. 1 ohms resistance o...   Apr 16 2021, 01:21 PM
euro911   Here's a good thread on testing and refurbishi...   Apr 16 2021, 02:07 PM
neilbardsley   Here's a good thread on testing and refurbish...   Apr 16 2021, 02:51 PM
Retroracer   Neil - so it does sound like a sender issue. Pres...   Apr 16 2021, 04:50 PM
neilbardsley   Thank you. Yes connecting directly to ground move...   Apr 16 2021, 11:53 PM
- Lo-Fi Version Time is now: 30th October 2026 - 02:58 PM
