Operation Integrity |
amfab |
Jan 1 2017, 11:34 AM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
OK, well I had to have a thread title. I am calling it that because it will restore structural integrity to the car and I want to be able to say that the rust has been correctly repaired if I eventually sell the car, unlike the lack of integrity of the person who hid the rust to sell it.
Pictures below The floor is a little shiny because there is still some mineral spirits on it from trying to get the tar off. The open areas that you are seeing are after I wire brushed with knotted wire wheels on a grinder, then a carbide burr on a die grinder. While I will take some more off, what you see is getting close to good weldable metal. First the longs: The driver’s side is the worst. The bottom edges inside and out were full of holes, or very thin, so I cut the outside of the driver’s all the way off—except I haven’t got to the front under the door pillar yet. I have cut out about 30 percent of the passenger’s side. The middle section is solid but I will replace it anyway. I started getting a little scared to take more out until I brace up the body. The floor pan: There are lots of sloppy welded patches and holes around the seams. The rear passenger’s and rear drivers quarters of the floor pan have been replaced with some plain steel—blue for some reason. The PO welded a solid bar on each side to mount the seat hinges. Sloppy, unground welds abound. There are some rust-through spots at the front of the pan that will need patching, but overall the pan in front of the cross member is solid. Some patches in the lower firewall are solid. Measuring diagonally, window frame to targa bar and straight back window frame to targa bar it is off no more than 1/8 inch. This changes depending upon doors open or closed or movement of the jack stands. The door gaps were never problems—maybe the driver’s side was a little wide. So it seems the car is pretty within spec and adjustable doorframe bars should be able to pull—or push—things to be good Here is where I need advice. This is my plan, please give feedback: 1) Pull Wiring harness, speedometer cable and gas lines out of the center tunnel (What else is in there?) pull gas tank. 2) Pull doors and build adjustable bars to align doorframes 3) Continue to grind back to clean metal in the inside of the longs. Sandblast, then create internal angled patch pieces to repair the inner longitudinals from 18ga cold rolled. I am using michelko’s example see: http://www.914world.com/bbs2/index.php?s=&...st&p=219748 4) Cut off the majority of the inner rockers (The upper half or three quarters of the longs are very solid) and replace with inner rockers from Restoration Design. 5) Coat interiors of longs with Ospho then Eastwood frame coating 6) Patch any inner long parts to the area aft of the Restoration Design patch with 18ga cold rolled steel. 7) Install Brad Mayuer reinforcement kit over the longs 8) Cut rear floor quarters and cross member out 9) Weld in new rear floor panel and cross member, grinding out old welds and creating flanges from18ga where necessary—in the spots where there is no flange left in spots along the firewall and inner long 10) Remove and rebuild pedal cluster and create patches for small rust spots in the front of the footwells. 11) Sandblast interior and prime and paint. 12) Cut holes for front sway bar, sand blast and prime and paint bottom of gas tank area. 13) Install gas tank, new stainless gas lines and reinstall wiring harness. Please give any feedback regarding my plan Attached thumbnail(s) |
amfab |
Jan 30 2017, 10:39 PM
You guys intimidate me. I am ok with a TIG, but I get sloppy with a MIG when Im not sitting at a table working on clean metal. I can not seem to get it dialed in.
Its like I get it dialed in then something changes. It does well for a while, then I have issues, then its back to good. Seems like a wire feed issue. I cleaned my wire drive wheel. It seemed to help. Do you guys run .030 or .025? Im using .030 with some standard Lincoln brand mild wire with 75% CO2-24% Argon. My welds should be better. Probably just me, I have been out of practice Anyway, I remade some patch parts because I chaged my mind how I was approaching this. I patched the damaged areas on the inside long. I butt-welded them in. They came out pretty good, but I want to make certain there is enough strength, so I am making an 18 gauge layer that will cover the inner long about 3/4 of the way up, from door post to engine mount. Below is the long before, repaired, and the last one is the shell I am building to reinforce it all. They are not as wavy in reality, The panoramic mode does that |
BeatNavy |
Jan 31 2017, 04:50 AM
Do you guys run .030 or .025? Im using .030 with some standard Lincoln brand mild wire with 75% CO2-24% Argon. My welds should be better. Probably just me, I have been out of practice I'm hardly the authority on this, but I use .030 for structural repairs (like you're doing now) and .025 for body/cosmetic stuff. Yes, that's the gas mixture I use as well. Really good welding has a lot of dependencies: clean metal, proper power/wire feed/gas settings, good technique (requiring lots of practice), good lighting, properly fitted patches, etc, etc. Most of the time I'm missing one or more of these elements, and my results, while functional, won't win any beauty contests. You're moving right along. I'm jealous...I need a heated garage with better light. My projects slow to a crawl in the winter... (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 05:13 AM |
