Electrical issues, Turn signal indicator |
80cap |
Feb 6 2017, 01:37 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok here's the deal. Turn signals and hazard lights all work. I just replaced the pea lights in the tach. I have no voltage to the socket, When I checked the wire it goes to ground. Looking for someone with more undamaged brain cells for trouble shooting ideas.
Brian (IMG:style_emoticons/default/headbang.gif) |
second wind |
Feb 6 2017, 05:43 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I would like to piggy back on this thread.....'73 2.0 with normal light bulbs and when you use turn signals first flash or two bright and clear in chosen indicator, then both indicators will blink at the same time but at only half brightness. Has been like this for years and I have scrubbed every ground in the car. Any ideas welcome.....thank you!!
gg |
Montreal914 |
Feb 6 2017, 11:20 PM
Senior Member Group: Members Posts: 1,588 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I would like to piggy back on this thread.....'73 2.0 with normal light bulbs and when you use turn signals first flash or two bright and clear in chosen indicator, then both indicators will blink at the same time but at only half brightness. Has been like this for years and I have scrubbed every ground in the car. Any ideas welcome.....thank you!! gg I've had the same problem since I bought the car 7 years ago. I replaced the flasher with another one (used (IMG:style_emoticons/default/dry.gif) ) and it didn't solved the problem. I always though that I needed to go in and clean the grounds but you have done that without success... (IMG:style_emoticons/default/sad.gif) I like Timothy's idea of connecting to the main circuits (IMG:style_emoticons/default/idea.gif). Strange that they have them separated (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:12 PM |
