Electrical issues, Turn signal indicator |
80cap |
Feb 6 2017, 01:37 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok here's the deal. Turn signals and hazard lights all work. I just replaced the pea lights in the tach. I have no voltage to the socket, When I checked the wire it goes to ground. Looking for someone with more undamaged brain cells for trouble shooting ideas.
Brian (IMG:style_emoticons/default/headbang.gif) |
Spoke |
Feb 8 2017, 12:16 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The diagram below shows what happens when the flasher K lead fails. Again the right side turnsignal is on (49a contact to the battery is closed) but the secondary coil controlling the contacts for output K has failed and remains open.
Now the center tap of the 2 tach indicator bulbs is not driven by output K. In this case output 49a powers both indicators (now in series) and then through the left side exterior bulbs. Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:32 AM |
