> Air/Fuel ratio, is there a quick answer?
malcolm2
post Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver.
The last adjustment of the CO screw has left me here:
I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif)
the idle is high.... at 1200 the A/F is a smooth 12.2.
I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5.
thoughts?
djway
post Feb 9 2017, 08:45 PM
You are running WAY to rich. At full throttle only guys with turbos or huge motors need below a 12 or 13, I don't remember which. There are a ton of post out there, and specs from Porsche. Cruising flat land the mixture should be at what is called Stoic which is short for stoichiometry which is used to figure out what is the best combination of compounds to get the max use out of everything involved. Cruising downhill you should go above 15.8, completely letting off throttle there should be almost no fuel and you will see very high numbers.
Look up factory specs and set to that at 3000rpm cruising flat land. Stoic for gasoline is 15.8
NO vacuum leaks anywhere
leak test all 5 injectors
check cold start valve for proper function.
check the ohms on the cht sensor. I have different units with different ohm readings and they greatly affect the stoic.
check the sensor and switch for WOT
crank case vent system can be checked if above measure don't help
checking flow rates of each injector if nothing above is helping.
compression more than 20lbs from the highest to lowest cylinder can cause problems
I knew nothing and read every article I could find an all the factory specs etc.
good luck
malcolm2   Air/Fuel ratio   Feb 5 2017, 05:50 PM
jim_hoyland   Got this from one of Chris Foley's posts in A...   Feb 5 2017, 06:09 PM
malcolm2   Great. I get to drive to work tomorrow (no rain). ...   Feb 5 2017, 06:34 PM
jim_hoyland   My experience ( before and after the top end rebui...   Feb 5 2017, 07:37 PM
pbanders   Agree with the ranges in Jim's posts for varyi...   Feb 5 2017, 10:22 PM
ottox914   Getting idle and AFR can be a challenge. As the en...   Feb 5 2017, 10:34 PM
plays with cars   Peak power is made around 13.5:1, idle is usually ...   Feb 6 2017, 12:10 AM
Mark Henry   I don't like to see much higher than 13:1 in a...   Feb 6 2017, 12:40 AM
Mueller   I don't like to see much higher than 13:1 in ...   Feb 10 2017, 03:52 PM
Mark Henry   [quote name='Mark Henry' post='2451811' date='Feb...   Feb 10 2017, 06:19 PM
timothy_nd28   :agree: Aircooled engines may need to run slight...   Feb 6 2017, 09:41 AM
72hardtop   :agree: Aircooled engines may need to run sligh...   Oct 29 2018, 02:29 AM
Keith914   When in doubt, do the spark plug color test.   Feb 6 2017, 10:45 AM
Mark Henry   When in doubt, do the spark plug color test. I s...   Feb 6 2017, 12:31 PM
porschetub   Doing final tune on my Zeniths,dropping idles down...   Feb 6 2017, 02:12 PM
Mark Henry   Mark what is the best performing/value AFR kit t...   Feb 6 2017, 05:13 PM
porschetub   Mark what is the best performing/value AFR kit ...   Feb 6 2017, 07:38 PM
malcolm2   Help me out with WOT. I played with that a little...   Feb 6 2017, 03:04 PM
timothy_nd28   I think it would be a cool gauge to have. Would i...   Feb 6 2017, 07:05 PM
Mark Henry   I think it would be a cool gauge to have. Would ...   Feb 6 2017, 11:06 PM
Porschef   It's a great tool to have, especially if you...   Feb 7 2017, 05:21 AM
McMark   Peak power is made around 13.5:1, ....That's t...   Feb 7 2017, 11:31 AM
ConeDodger   Peak power is made around 13.5:1, ....That's ...   Feb 7 2017, 11:46 AM
Mark Henry   [quote name='McMark' post='2452311' date='Feb 7 2...   Feb 7 2017, 12:05 PM
malcolm2   But on top of the WB meter you should have a head...   Feb 7 2017, 02:18 PM
timothy_nd28   350 degrees is not normal, atleast I hope not. Re...   Feb 7 2017, 08:47 PM
malcolm2   350 degrees is not normal, atleast I hope not. R...   Feb 8 2017, 11:32 AM
malcolm2   350 degrees is not normal, atleast I hope not. R...   Feb 8 2017, 12:02 PM
Vacca Rabite   350 degrees is not normal, atleast I hope not. R...   Apr 27 2017, 09:13 AM
malcolm2   I'd love to see 350 at 70MPH running up some ...   Apr 28 2017, 06:29 AM
ConeDodger   The good thing about a CHT gauge is you know your ...   Feb 7 2017, 08:51 PM
Mark Henry   The good thing about a CHT gauge is you know your...   Feb 8 2017, 07:33 AM
malcolm2   The good thing about a CHT gauge is you know you...   Feb 8 2017, 11:37 AM
djway   When I set up my L jet that had been horribly mess...   Feb 8 2017, 10:11 PM
malcolm2   When I set up my L jet that had been horribly mes...   Feb 9 2017, 10:15 AM
djway   You are running WAY to rich. At full throttle onl...   Feb 9 2017, 08:45 PM
jcd914   If your air flow meter has been mucked with alread...   Feb 10 2017, 12:55 AM
falcor75   Stoic for gasoline is 15.8 Ummm, I dont know ...   Feb 10 2017, 01:34 AM
djway   Stoic for gasoline is 15.8 Ummm, I dont know...   Feb 10 2017, 04:07 AM
Mark Henry   If you are running at stoich AFR on an aircooled y...   Feb 10 2017, 10:03 AM
malcolm2   On WOT are you documenting at bottom value? I ten...   Feb 10 2017, 11:41 AM
malcolm2   On WOT are you documenting at bottom value? I te...   Feb 14 2017, 01:30 PM
Porschef   Clark, are you referring to the screw on the AFM i...   Feb 10 2017, 11:56 AM
malcolm2   Clark, are you referring to the screw on the AFM ...   Feb 10 2017, 03:21 PM
Porschef   Mark, i get the nickies can deal with a leaner mix...   Feb 10 2017, 11:58 AM
Porschef   IIRC, I'm at 13.2 or so at cruise. The engine ...   Feb 10 2017, 12:06 PM
malcolm2   Of course, there shall be no vacuum leaks... ...   Feb 10 2017, 03:26 PM
timothy_nd28   If you have smoke coming out from the dizzy, you w...   Feb 10 2017, 04:10 PM
malcolm2   If you have smoke coming out from the dizzy, you ...   Feb 10 2017, 04:58 PM
timothy_nd28   AA is now closed, so now your thinking RTV? :D ...   Feb 10 2017, 05:23 PM
malcolm2   AA is now closed, so now your thinking RTV? :D ...   Feb 11 2017, 08:37 AM
Mark Henry   Just a FYI, PLX has their O2 WB meters on sale ...   Feb 10 2017, 06:24 PM
malcolm2   Just a FYI, PLX has their O2 WB meters on sale ...   Feb 11 2017, 08:33 AM
Mark Henry   [quote name='Mark Henry' post='2453440' date='Feb...   Feb 11 2017, 10:16 AM
timothy_nd28   Those numbers are better than the 18+ numbers you ...   Feb 14 2017, 01:47 PM
malcolm2   Those numbers are better than the 18+ numbers you...   Feb 14 2017, 02:37 PM
stugray   Any leaks coming from the valve cover, dipstick, o...   Feb 14 2017, 02:40 PM
timothy_nd28   You tell yourself that while trying to start a Lje...   Feb 14 2017, 03:26 PM
pete000   Great read, I am in the exact situation with my 1....   Feb 14 2017, 04:29 PM
malcolm2   No adjustments or significant changes to the readi...   Feb 24 2017, 10:14 AM
timothy_nd28   I think your old bent AFM was adjusted abit rich.   Feb 24 2017, 10:33 AM
malcolm2   I think your old bent AFM was adjusted abit rich....   Feb 24 2017, 01:01 PM
malcolm2   Mark, I have been studying up on your AFR link fro...   Feb 24 2017, 01:04 PM
veekry9   No quick answers,because it's complicated,many...   Feb 24 2017, 03:53 PM
pete000   I picked up one of the PLX Blue Tooth AFR systems ...   Mar 5 2017, 12:56 AM
Mark Henry   Yes 15:1 cruise is too lean for an aircooled 14:1 ...   Mar 5 2017, 07:55 AM
72hardtop   Yes 15:1 cruise is too lean for an aircooled 14:1...   Apr 24 2017, 05:49 AM
McMark   I agree with and support everything Mark Henry has...   Mar 5 2017, 09:46 AM
malcolm2   My PLX rig showed up Friday. Looking forward to ge...   Mar 5 2017, 08:01 PM
pete000   My PLX rig showed up Friday. Looking forward to g...   Mar 6 2017, 11:20 PM
timothy_nd28   Be careful. The air flow meter has a wound up clo...   Mar 7 2017, 11:22 AM
malcolm2   Be careful. The air flow meter has a wound up cl...   Mar 7 2017, 02:16 PM
pete000   Sounds like these early FI cars are set from the f...   Mar 7 2017, 10:59 PM
malcolm2   I do like welding stuff.... but man you can screw ...   Mar 10 2017, 02:30 PM
Mark Henry   Was your wire feed sticking? You likely need a new...   Mar 10 2017, 03:04 PM
malcolm2   Was your wire feed sticking? You likely need a ne...   Mar 10 2017, 03:10 PM
malcolm2   PLX is now installed. The guage is temp'd in w...   Mar 23 2017, 09:55 AM
pete000   I have been playing around a bit with my AFM. I ha...   Mar 23 2017, 06:57 PM
malcolm2   My AFM has that jumper. Did not know it was an add...   Mar 24 2017, 06:22 AM
malcolm2   5 hours of interstate driving. Several big hills. ...   Mar 24 2017, 06:23 AM
Porschef   Hey Clark, PM sent Joe   Mar 24 2017, 07:50 AM
timothy_nd28   Sounds like you are around 26 mpg. I think with t...   Mar 24 2017, 10:15 AM
timothy_nd28   I take back what I said. Maybe you are already ge...   Mar 24 2017, 10:48 AM
pete000   Tested out my AFM mods and seemed to work well. Wa...   Mar 24 2017, 04:49 PM
malcolm2   I made it home.... 800 + mile weekend trip. I don...   Mar 27 2017, 03:16 PM
malcolm2   Ok what do you think? Maybe 1000 miles with this ...   Mar 27 2017, 04:33 PM
72hardtop   Ok what do you think? Maybe 1000 miles with this...   Oct 29 2018, 02:19 AM
timothy_nd28   I got nothing. My work with you is done.   Mar 27 2017, 05:10 PM
Mark Henry   I'd say that plug is a tad hot, what number is...   Mar 27 2017, 05:17 PM
malcolm2   I'd say that plug is a tad hot, what number i...   Mar 27 2017, 07:11 PM
Olympic 1.7   Spark plugs are an easy change, you could try NGK ...   Mar 28 2017, 07:55 AM
72hardtop   This is a great graph for air cooled engines: htt...   Apr 24 2017, 05:38 AM
jpapatrout   I just saw an ad for an AFR from Innovate that mon...   May 6 2017, 04:24 PM
914Toy   I just saw an ad for an AFR from Innovate that mo...   Nov 1 2018, 09:13 AM
Chi-town   There is no "short answer" for this ques...   Oct 29 2018, 10:36 AM
72hardtop   There is no "short answer" for this que...   Nov 1 2018, 12:04 AM
- Lo-Fi Version Time is now: 1st October 2026 - 12:38 AM
