> Troubleshooting my electrical issues., My first problem was blinking red light on the dash for brakes
vin man
post Feb 11 2017, 06:08 PM
Edit: Renamed the thread because what started out as one electrical problem has led to others and I'm hoping to capture all the information in this one thread.
Initial Problem:
When I turn on the 72, the red light on the dash (in the top part of the gauge on the left side of the dash) blinks and won't stop. I've made sure the e-brake is all the way off. I'm wondering where is the switch that controls this light?
I've read that when the brake master cylinder is replaced, there is a switch on the MC that needs to be reset. I used a MC from Rock Auto and there is not reset switch button. Only the electrical switch that activates the brake lights.
I have a brown wire that is connected to nothing in the area of the e-brake handle. I've tried grounding it but the light still blinks on the dash.
Any advice would be appreciated.
Click here for video of the blinking light: Blinking red light
(IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858110.1.jpg)
Master cylinder:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858537.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858538.2.jpg)
Spoke
post Feb 11 2017, 10:32 PM
Jerry
The brake warning light will flash if the brown wire by the e-brake is grounded. Also if the switch on the MC is closed. Try disconnecting the wires on the MC switch and the e-brake wire is not grounded. This should cause the flashing light to stop.
vin man
post Feb 12 2017, 11:46 AM
QUOTE(Spoke @ Feb 11 2017, 09:32 PM) *
I took the wires off the MC and the wire off the switch at the handbrake. The light still flashes on the dash.
rgalla9146
post Feb 12 2017, 12:23 PM
QUOTE(vin man @ Feb 12 2017, 12:46 PM) *
Find the wire at the hand brake switch and disconnect it.
Follow it out of the seat crossmember and wherever it goes to
be sure it is not making contact with anything that could ground it.
vin man   Troubleshooting my electrical issues.   Feb 11 2017, 06:08 PM
Spoke   The brake warning light will flash if the brown wi...   Feb 11 2017, 10:32 PM
vin man   The brake warning light will flash if the brown w...   Feb 11 2017, 10:43 PM
vin man   The brake warning light will flash if the brown w...   Feb 12 2017, 11:46 AM
rgalla9146   The brake warning light will flash if the brown ...   Feb 12 2017, 12:23 PM
vin man   [quote name='vin man' post='2453875' date='Feb 12...   Feb 12 2017, 01:31 PM
vin man   I've been doing some more research and did fin...   Feb 11 2017, 10:45 PM
AlanB   Wow, talk about the right post at the right time. ...   Feb 12 2017, 08:01 AM
Spoke   You can pull the bulb out to stop the flashing.   Feb 12 2017, 01:58 PM
vin man   You can pull the bulb out to stop the flashing. w...   Feb 12 2017, 03:45 PM
Spoke   You can pull the bulb out to stop the flashing. ...   Feb 12 2017, 05:03 PM
vin man   [quote name='vin man' post='2453938' date='Feb 12...   Feb 12 2017, 05:25 PM
Spoke   If I do as suggested and remove the bulb, breaking...   Feb 12 2017, 06:51 PM
vin man   If I do as suggested and remove the bulb, breakin...   Feb 12 2017, 09:47 PM
vin man   [quote name='vin man' post='2453959' date='Feb 1...   Feb 13 2017, 05:18 PM
Rand   Isn't there a reset button on the master cylin...   Feb 12 2017, 05:44 PM
vin man   Isn't there a reset button on the master cyli...   Feb 12 2017, 05:59 PM
ndfrigi   i did remove the bulb from the gauge 4 yrs ago. no...   Feb 12 2017, 06:09 PM
vin man   i did remove the bulb from the gauge 4 yrs ago. n...   Feb 12 2017, 06:15 PM
ndfrigi   or maybe the noise is for the door when it is open...   Feb 13 2017, 05:24 PM
Dave_Darling   The door-ajar buzzer does not sound like clicking....   Feb 13 2017, 06:05 PM
vin man   New relay will be delivered on Wednesday. switch f...   Feb 13 2017, 07:45 PM
Spoke   New relay will be delivered on Wednesday. Where...   Feb 15 2017, 12:10 PM
vin man   [quote name='vin man' post='2454367' date='Feb 13...   Feb 15 2017, 12:32 PM
Spoke   Autozone also has one. This is the one from Aut...   Feb 15 2017, 02:50 PM
vin man   [quote name='vin man' post='2454904' date='Feb 15...   Feb 15 2017, 03:00 PM
vin man   I just wanted to add some more information on what...   Feb 14 2017, 12:16 PM
vin man   Well now I'm really baffled. I replaced the r...   Feb 14 2017, 03:50 PM
914_teener   Man...ya get bonus points. Keep at it. Have you ...   Feb 14 2017, 08:17 PM
Spoke   What is the part number on that blinker. Not the p...   Feb 15 2017, 04:05 PM
vin man   A few pics. The first is the original relay tha...   Feb 15 2017, 08:35 PM
Dave_Darling   URO... Not exactly the highest quality. I believ...   Feb 15 2017, 10:23 PM
vin man   URO... Not exactly the highest quality. I belie...   Feb 16 2017, 08:35 AM
vin man   Anyone have a recommendation for a person/company ...   Feb 16 2017, 10:18 AM
scallyk9   Hmm. I've got a similar problem with the indic...   Feb 16 2017, 05:45 PM
vin man   :Qarl: Got it working! An electrical genius...   Feb 16 2017, 11:03 PM
vin man   Problem #3 Premature celebration. :headbang: On...   Feb 19 2017, 12:55 PM
vin man   Update: I was concerned that maybe I did not wire...   Feb 21 2017, 08:48 PM
Dave_Darling   Unplug the switch? --DD   Feb 21 2017, 10:55 PM
vin man   Unplug the switch? --DD Will give it a try to...   Feb 22 2017, 04:21 PM
914_teener   You rule each thing out. You test input and out ...   Feb 22 2017, 04:56 PM
vin man   Ruled out headlight switch and brake light switch....   Feb 24 2017, 09:18 PM
vin man   ok, issues 3 (and 4) resolved. After resolving Is...   Feb 28 2017, 03:37 PM
mgphoto   There are 2 diodes behind the combo gauge, the bra...   Mar 1 2017, 09:24 AM
- Lo-Fi Version Time is now: 4th March 2026 - 05:22 AM
