| vin man |
Feb 11 2017, 06:08 PM
Member ![]() ![]() Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Edit: Renamed the thread because what started out as one electrical problem has led to others and I'm hoping to capture all the information in this one thread.
Initial Problem: When I turn on the 72, the red light on the dash (in the top part of the gauge on the left side of the dash) blinks and won't stop. I've made sure the e-brake is all the way off. I'm wondering where is the switch that controls this light? I've read that when the brake master cylinder is replaced, there is a switch on the MC that needs to be reset. I used a MC from Rock Auto and there is not reset switch button. Only the electrical switch that activates the brake lights. I have a brown wire that is connected to nothing in the area of the e-brake handle. I've tried grounding it but the light still blinks on the dash. Any advice would be appreciated. Click here for video of the blinking light: Blinking red light (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858110.1.jpg) Master cylinder: (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858537.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858538.2.jpg) |
| Spoke |
Feb 12 2017, 01:58 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,348 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
You can pull the bulb out to stop the flashing.
| vin man |
Feb 12 2017, 03:45 PM
| Spoke |
Feb 12 2017, 05:03 PM
You can pull the bulb out to stop the flashing. The relay will stop flashing when the bulb is removed. See the turnsignal/brake warning schematic below. one of the wires from either the MC switch or the e-brake switch is shorting to chassis. Removing the bulb will break the circuit and the flasher relay will not operate. This isn't a fix of course because somewhere the wire to the MC switch or e-brake is grounded. When you fix the grounded wire, you can put the bulb back in. My guess is the brown wire to the e-brake is touching the chassis under the seat or throughout its run to the bulb. Attached image(s)
| vin man |
Feb 12 2017, 05:25 PM
You can pull the bulb out to stop the flashing. The relay will stop flashing when the bulb is removed. See the turnsignal/brake warning schematic below. one of the wires from either the MC switch or the e-brake switch is shorting to chassis. Removing the bulb will break the circuit and the flasher relay will not operate. This isn't a fix of course because somewhere the wire to the MC switch or e-brake is grounded. When you fix the grounded wire, you can put the bulb back in. My guess is the brown wire to the e-brake is touching the chassis under the seat or throughout its run to the bulb. If I do as suggested and remove the bulb, breaking the circuit of the flasher relay - will my turn signals still work? I removed the relay and the turn signals did not work. I want to fix it properly and find the short, but in the interim, I don't mind pulling the bulb provided I will still have turn signal functionality. Unfortunately, when it comes to electrical diagrams, I don't comprendo well. |
| Spoke |
Feb 12 2017, 06:51 PM
If I do as suggested and remove the bulb, breaking the circuit of the flasher relay - will my turn signals still work? Removing the bulb will not affect the turnsignals. Porsche designers had the bright idea to double use the flasher for turnsignals and to flash the brake warning light. I thought in the first pic the wire to the e-brake switch was disconnected. |
vin man Troubleshooting my electrical issues. Feb 11 2017, 06:08 PM
Spoke The brake warning light will flash if the brown wi... Feb 11 2017, 10:32 PM
vin man
The brake warning light will flash if the brown w... Feb 11 2017, 10:43 PM
vin man
The brake warning light will flash if the brown w... Feb 12 2017, 11:46 AM
rgalla9146
The brake warning light will flash if the brown ... Feb 12 2017, 12:23 PM
vin man
[quote name='vin man' post='2453875' date='Feb 12... Feb 12 2017, 01:31 PM
vin man I've been doing some more research and did fin... Feb 11 2017, 10:45 PM
AlanB Wow, talk about the right post at the right time. ... Feb 12 2017, 08:01 AM
vin man
If I do as suggested and remove the bulb, breakin... Feb 12 2017, 09:47 PM
vin man
[quote name='vin man' post='2453959' date='Feb 1... Feb 13 2017, 05:18 PM
Rand Isn't there a reset button on the master cylin... Feb 12 2017, 05:44 PM
vin man
Isn't there a reset button on the master cyli... Feb 12 2017, 05:59 PM
ndfrigi i did remove the bulb from the gauge 4 yrs ago. no... Feb 12 2017, 06:09 PM
vin man
i did remove the bulb from the gauge 4 yrs ago. n... Feb 12 2017, 06:15 PM
ndfrigi or maybe the noise is for the door when it is open... Feb 13 2017, 05:24 PM
Dave_Darling The door-ajar buzzer does not sound like clicking.... Feb 13 2017, 06:05 PM
vin man New relay will be delivered on Wednesday.
switch f... Feb 13 2017, 07:45 PM
Spoke
Where... Feb 15 2017, 12:10 PM
vin man
[quote name='vin man' post='2454367' date='Feb 13... Feb 15 2017, 12:32 PM
Spoke
Autozone also has one. This is the one from Aut... Feb 15 2017, 02:50 PM
vin man
[quote name='vin man' post='2454904' date='Feb 15... Feb 15 2017, 03:00 PM
vin man I just wanted to add some more information on what... Feb 14 2017, 12:16 PM
vin man Well now I'm really baffled. I replaced the r... Feb 14 2017, 03:50 PM
914_teener Man...ya get bonus points.
Keep at it.
Have you ... Feb 14 2017, 08:17 PM
Spoke What is the part number on that blinker. Not the p... Feb 15 2017, 04:05 PM
vin man A few pics.
The first is the original relay tha... Feb 15 2017, 08:35 PM
Dave_Darling URO... Not exactly the highest quality.
I believ... Feb 15 2017, 10:23 PM
vin man
I belie... Feb 16 2017, 08:35 AM
vin man Anyone have a recommendation for a person/company ... Feb 16 2017, 10:18 AM
scallyk9 Hmm. I've got a similar problem with the indic... Feb 16 2017, 05:45 PM
vin man :Qarl:
Got it working!
An electrical genius... Feb 16 2017, 11:03 PM
vin man Problem #3
Premature celebration. :headbang:
On... Feb 19 2017, 12:55 PM
vin man Update:
I was concerned that maybe I did not wire... Feb 21 2017, 08:48 PM
Dave_Darling Unplug the switch?
--DD Feb 21 2017, 10:55 PM
vin man
Unplug the switch?
--DD
Will give it a try to... Feb 22 2017, 04:21 PM
914_teener You rule each thing out.
You test input and out ... Feb 22 2017, 04:56 PM
vin man Ruled out headlight switch and brake light switch.... Feb 24 2017, 09:18 PM
vin man ok, issues 3 (and 4) resolved.
After resolving Is... Feb 28 2017, 03:37 PM
mgphoto There are 2 diodes behind the combo gauge, the bra... Mar 1 2017, 09:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 05:22 AM |
