| McMark |
Feb 15 2017, 12:23 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I don't think I ever posted this tutorial with pictures, but I've mentioned it a few times.
These plugs are useful for anytime you're working on your brakes and are really easy to make. If you're pulling your calipers you can install these in the ends of the soft lines to keep them from dripping. If you're replacing your master cylinder these will let you bleed the MC. Keep them handy. You can use a similar process with the female fittings on an old rubber line to make female plugs. Here we go! First snip a section off of an old brake line, or a universal bubble-flare line from the parts store. Crimp the end shut, to keep the solder from running out when it's liquid as well as to keep the nut from sliding off the end when not in use. This is plenty of crimp. Cut a small piece of thick solder that will slip inside the tube. Slide the solder into the tube, and let it drop down to the crimped end. Using a pair of pliers or a vice or any other suitable device, hold the brake plug upright as pictured and heat sufficiently to melt the solder. In this case the crimp was glowing slightly red hot. Let cool or spritz with water. And make as many as you need. ![]() |
| TheCabinetmaker |
Feb 15 2017, 02:44 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Why not just use flare fitting plugs?
McMark HOW TO: Build brake line plugs. Feb 15 2017, 12:23 PM
76-914 Good idea. But that isn't plumbers solder. :b... Feb 15 2017, 02:01 PM
McMark
Good idea. But that isn't plumbers solder. :... Feb 15 2017, 03:08 PM
McMark
I'm su... Feb 15 2017, 03:10 PM
draganc
Because i... Feb 15 2017, 11:08 PM
The Cabinetmaker Well, I suppose that might be true, but just about... Feb 15 2017, 03:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 01:58 AM |
