STILL NO BRAKES! |
STILL NO BRAKES! |
JHop |
Feb 14 2017, 06:59 PM
Newbie Group: Members Posts: 28 Joined: 18-February 16 From: Portland, OR Member No.: 19,685 Region Association: Pacific Northwest |
Gents,
I have done the searches, watched some video, looked up stuff, rebuilt my calipers, replaced the MC, soft brake lines, and some hard lines, new pads and hardware, adjusted the venting clearance on the rear pads, speed bleeders...probably going on about $600 all in on this brake system so far...bled , then bled, then bled some more using a pressure bleeder...still a soft pedal and red blinky brake dash light when the pedal goes to the floor. I tried to do the pedal bleed, but it didn't seem like the fluid was moving. When I switched to the pressure bleeder, the fluid started coming out...no air bubbles. What am I missing? Adjust the venting again? If I did that wrong, does it screw up the whole system? Car runs, is looking good...needs to STOP. (IMG:style_emoticons/default/headbang.gif) |
TheCabinetmaker |
Feb 15 2017, 03:57 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What brand, and where did you buy said master cylinder? I put 4 master cylinders on my truck before I got one that worked.
JHop |
Feb 15 2017, 10:22 PM
What brand, and where did you buy said master cylinder? I put 4 master cylinders on my truck before I got one that worked. Bought the MC from local import auto place that specializes in VW/Porsche. FTE was what it said on the box...I hope I'm not going through that many... (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:00 PM |
