| nsyr |
Oct 24 2004, 03:29 PM
Because I Can ![]() ![]() Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
Anyone try this or know how to go about doing it. I think it would look really good having all one piece window compared to having the wing part.
| neo914-6 |
Oct 24 2004, 07:14 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
QUOTE Where would you be able to get the one piece glass that would fit? The mechanics of it is not a big deal, I know I could make it work. I've been working on this for my modern 914 project. It requires more bracing because there will be little glass left in the door when fully raised. Basically the glass is the costly part to produce. By astronomical chance there may be an existing side glass that has the same dimensions needed but the likely solution is a custom manufactured piece. There should be some companies that will do small runs but it will still require a small fortune in tooling. Remember this is slightly curved glass. I designed some custom pieces 20 years ago for a bus company. All this could be feasible if a few hundred of these were manufactured. I'm not sure what kind of DOT or NHTSA approval it would require but again more money for testing than most are willing to invest. You could try the "for racing purposes only" waiver but it may be too obvious that racers use plastic or nets. Another alternative is plexiglass or lexan which is a compromise in stiffness or scratch resistance. The shops that rake the windshield use plexiglass on their side windows. You would think they would invest in this idea since they are in the business of "styling". Felix |
nsyr Single piece door windows Oct 24 2004, 03:29 PM
McMark The biggest issue I can see is the front guide. Y... Oct 24 2004, 03:40 PM
Jeroen If you do a lot of windows down driving, you won... Oct 24 2004, 03:48 PM
boxstr I have been thinking about this for a longtime. Lo... Oct 24 2004, 03:50 PM
ruddyboys Why didn't they make the vent window tilt out?... Oct 24 2004, 06:08 PM
tod914 Same reason they went to plastic interior componen... Oct 24 2004, 06:12 PM
nsyr Where would you be able to get the one piece glass... Oct 24 2004, 06:36 PM
nsyr I got my avatar pic off the internet. It's the... Oct 24 2004, 06:54 PM
Cap'n Krusty
nsyr I remember seeing this done on a Falcon on Overhau... Oct 24 2004, 07:35 PM
boxstr On Overhaulin the glass guy put a line of powder t... Oct 24 2004, 08:05 PM
rhodyguy don't forget the long squeegee and the metal c... Oct 24 2004, 08:12 PM
neo914-6
DougC What I've thought of doing and is "sort of" al... Oct 25 2004, 10:17 AM
Root_Werks On the VW kits, they use the cable door stop. I t... Oct 25 2004, 12:22 PM
neo914-6
r_towle lexan wont work for a movable window, it sratches ... Oct 25 2004, 07:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:54 PM |
