> Hydraulic lifters, Web-Cam
watsonrx13
post Oct 24 2004, 02:01 PM
OK, Joe Ricard has just informed me that he's received the new lifters for my rebuild. They are the Web-Cam Performance Lifters, ordered through PP, as recommended for the Web-Cam camshaft for carbureted cars.
Is this good, bad, correct, wrong?
I'm confused (IMG:style_emoticons/default/blink.gif)
Do I need to call PP and get an exchange?
If I should get an exchange, what should I order?
This car is going to be a driver with occasional AX runs. Joe is rebuilding the engine, it's a 2.0l with 94mm P/C, twin 40 IDF, 9.2:1 CR. I'm looking for reliability and dependibility.
Jake Raby
post Oct 24 2004, 07:18 PM
Engine Surgeon
I developed this
http://www.aircooledtechnology.com/lifters.htm
To test lifters and camshafts as well as break them in prior to use so they could be inspected for wear..
There are no good conventional lifters out there.. Out of the 65 sets that we have tested 50 or so of them have had uneven wear, or signs of going flat.
The problems are numerous and I'm still working to make it all better. Its to the point where EVERY engine we build gets ceramics- No risk taking here.
The lifters you have thatare solid but rattle are web cam solid lifters. That two piece design is the reason we don't fancy them. I am working with another company to make an insert that will go inside the lifter and get rid of the rattles and lash issues that it can cause.
This testing has sucked, after almost 8,000.00 worth of cams, lifters, and prototypes the problems still are not cured. The next step is Billetcams ground with more taper for a higher lifter surface speed, coupled with all components being fully micropolished to a mirror finish to to reduce friction and load points....
Nothing off the shelf is perfect these days with lifters. I have to get this straightened out because I'll starve if we don't! 8 months of backlog does no good if we can't assemble anything!
watsonrx13   Hydraulic lifters   Oct 24 2004, 02:01 PM
MattR   I think the consensus is: stay away from hydraulic...   Oct 24 2004, 02:16 PM
F4i   are you sure they are hyd. lifters? The "solid" on...   Oct 24 2004, 02:18 PM
Demick   The new solid lifters are 2-piece. Shake them and...   Oct 24 2004, 05:56 PM
Joe Ricard   Yup these rattle. So what's the deal never see...   Oct 24 2004, 06:48 PM
StratPlayer   Hey Dimick,,, were those ceramic lifters drop in o...   Oct 24 2004, 06:53 PM
Jake Raby   I developed this http://www.aircooledtechnology.c...   Oct 24 2004, 07:18 PM
Demick
- Lo-Fi Version Time is now: 20th September 2026 - 12:17 PM
