STILL NO BRAKES! |
STILL NO BRAKES! |
JHop |
Feb 14 2017, 06:59 PM
Newbie Group: Members Posts: 28 Joined: 18-February 16 From: Portland, OR Member No.: 19,685 Region Association: Pacific Northwest |
Gents,
I have done the searches, watched some video, looked up stuff, rebuilt my calipers, replaced the MC, soft brake lines, and some hard lines, new pads and hardware, adjusted the venting clearance on the rear pads, speed bleeders...probably going on about $600 all in on this brake system so far...bled , then bled, then bled some more using a pressure bleeder...still a soft pedal and red blinky brake dash light when the pedal goes to the floor. I tried to do the pedal bleed, but it didn't seem like the fluid was moving. When I switched to the pressure bleeder, the fluid started coming out...no air bubbles. What am I missing? Adjust the venting again? If I did that wrong, does it screw up the whole system? Car runs, is looking good...needs to STOP. (IMG:style_emoticons/default/headbang.gif) |
stugray |
Feb 14 2017, 11:44 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Do you have the calipers installed where the bleeders are at the top of the calipers?
And if you have any calipers with two bleeders, you are using the top ones? |
JHop |
Feb 14 2017, 11:49 PM
Do you have the calipers installed where the bleeders are at the top of the calipers? And if you have any calipers with two bleeders, you are using the top ones? Yes, the rears have the two bleeders, and I've only used the top ones...still no pedal at all. Man, I just want to be able to drive this car...it's killing me. If there is anyone in the Portland, OR area that can help me I'll be forever grateful! |
jsaum |
Feb 16 2017, 09:51 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Do you have the calipers installed where the bleeders are at the top of the calipers? And if you have any calipers with two bleeders, you are using the top ones? Yes, the rears have the two bleeders, and I've only used the top ones...still no pedal at all. Man, I just want to be able to drive this car...it's killing me. If there is anyone in the Portland, OR area that can help me I'll be forever grateful! And your front calipers have the bleeders on top too? It took me a week to figure out I had them on the wrong sides. I ran three large bottles of fluid through while trying to bleed the system. Once I switched them I had a firm pedal in minutes! Oh and I now have a really cleanly flushed out brake system! Hang in there you'll figure it out. Jsaum |
JHop |
Feb 18 2017, 02:14 PM
Do you have the calipers installed where the bleeders are at the top of the calipers? And if you have any calipers with two bleeders, you are using the top ones? Yes, the rears have the two bleeders, and I've only used the top ones...still no pedal at all. Man, I just want to be able to drive this car...it's killing me. If there is anyone in the Portland, OR area that can help me I'll be forever grateful! And your front calipers have the bleeders on top too? It took me a week to figure out I had them on the wrong sides. I ran three large bottles of fluid through while trying to bleed the system. Once I switched them I had a firm pedal in minutes! Oh and I now have a really cleanly flushed out brake system! Hang in there you'll figure it out. Jsaum Yeah, the calipers are correct...just pressurized the system with the presssure bleeder...firm pedal! So, what does THAT mean? |
Lo-Fi Version | Time is now: 7th June 2024 - 06:40 PM |
